Results 1 to 5 of 5
Thread: ta22 engine conversion
    Junior Member Grease Monkey imlach74's Avatar
    victoria
    Default ta22 engine conversion
    ivejust brought a ta22 and i want to know the best engine conversion to do
    my budget is around $3000...also i need tips on diff,gearbox and anyhing else you can help me with..thanks
    Default Re: ta22 engine conversion
    The cheapest with good results is the 2tg or 2tgeu. Plenty of benifits of doing this one. Little or no modification to the rest of the drivetrain is required. A brake upgrade isn't fully neccesary if you have decent pads - Although would be nice. Can get away with this without engineering. Is a relatively cheap option. Run on twin carbs(solexes, webbers, dellortos. 40,44,45 mms) or the 2tgeu efi setup.
    Next up is the 3tgte. Will require a stronger gearbox, some modification of the engine crossmember, a brake upgrade, fuel system upgrade(High pressure pump, efi hoses, optional surge tank, etc).
    Then there's the 4agze option...
    For an endless wealth of information use the search function. Spend a few days reading other people's experiences then post when you are absolutely stuck.
    Finally, for 3k you will be doing all the work yourself.
    Quote Originally Posted by imlach74
    It's all there to search for... There's countless amounts of info on here!
    ([][][]II--LT--II[][][])
    Junior Member 1st year Apprentice Mr_Toyota's Avatar
    tasmania
    Ive read 2t 3t hybrid motors with a Turbo hanging on the side make decent power, something to look into i guess..
    Im not flaming but this is so covered and there was even an almost identical thread to this yesterday.
    - LeeRoy
  1. Toyota R Engine History
  2. MZ20 - 7MGTE To 1JZGTE Conversion Pics (56K Warning)
    By Danners in forum Engine & Driveline Conversions
    Last Post: 07-05-2008, 10:02 AM
  3. MA70 --> JZA70 Conversion
  4. TA22 18rg conversion carbie issues
    By picko87 in forum Tech and Conversions
    Last Post: 23-08-2006, 08:44 PM
  5. Engine conversion for ta22 celica
    By jp_ta22 in forum Tech and Conversions
    Last Post: 03-08-2006, 11:03 PM
