Results 1 to 12 of 12
Thread: Aftermarket Temp Sender Location
    Default Aftermarket Temp Sender Location
    I'm installing an aftermarket temp guage in my 1JZ-GTE, was thinking of using one of those adapters that you add into the rad. hose, just wondering which hose? upper or lower? how good an indication of coolant temp would this give? anyone else install a aftermarket guage but still wish to maintain the factory guage? ideas please
    RogueVL
    Junior Member Backyard Mechanic STR8 2.8's Avatar
    Default Re: Aftermarket Temp Sender Location
    upper would be better as its come straight from the head, not the radiator, so it will give a better indication of the temps
    I have a Crown
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    Quote Originally Posted by rogue-vl
    RogueVL
    Highest water temp is at outlet from the head [carrying the heat load to the radiator]. as STR8_2.8 said this is in the top hose between the thermostat housing and the radiator.
    1. There's no point arguing with an idiot. They'll just drag you down to their level and beat you with experience
    2. Don't argue with an idiot; people watching may not be able to tell the difference
    S.A
    The top hose is the best place. Is it a screw in type sensor ??
    I run my EMS sensor in the block on my car and it works quite well. The read out is digital so you can see the temp rise 1 deg at a time . This is particularly handy on the dyno.
    I still also use the factory temp gauge in the head which is connected to the factory gauge in the dash.
    If you can i would recommend using both gauges (factory and aftermarket) as it can be very handy esp if the sensors are located in different spots on the motor .
    This will give you a good idea of how the heat is being conducted
    remember that the sensor body (unless it is a two wire) needs to be earthed thru the body of the sensor...
    where it goes depends on what temp you want to read....
    before the thermostat? after the thermostat? after the radiator?
    i would vote before the thermostat, so that you can see when it opens, and when it closes...
    failing that, top hose...
    Not just a regular Backyard Mechanic ProjectSleeper's Avatar
    I have been looking for the Radiator hose sensor/adaptors but can not find any...
    anyone have an idea where I can get one in Sydney ??
    umm there are Greddy or something types at the local autobacs around $80-100 i think? maybe less....
    I got mine off Ebay, $32 delivered, and it also comes with a small bolt whoch screws into the body of the adapter to mount an earth wire to, 1st one i have seen with this.
    This is the store i got mine from
    http://stores.ebay.com.au/Car-Access...QQftidZ2QQtZkm
    Ok so the top hose is the best location, where i had originally planned.
    Thanks once again guys.
    Awesome, thanks heaps...
    Quick couple of questions on them.
    1. The 40/42mm - is that Inside or Outside Diameter of the tube
    2. Do they come pre-drilled and tapped for the probe - if so, what size thread/pitch etc
    3. what is the quality like ? - appear robust enough and not cheaply made etc ??
    Yes the come pre drilled 1/8npt the standard for most oil and water senders,
    40/42 is the od of the adapter, same as ID os hose,
    quality seems to me to be exellent, comparable to the greddy ones
    Awesome, Thanks again...
    I'll buy one..
    Western Aus
    like dis here...
    spread the 7M love ya'll.
    Eldar.O.
  1. Oil Pressure Sender Location
    By Timma in forum Tech and Conversions
    Last Post: 14-09-2006, 06:13 PM
  2. 1G aftermarket temp guage install.
    By Mr Multivalve in forum Tech and Conversions
    Last Post: 22-06-2006, 06:47 PM
  3. RA/TA2x oil temp gauge sender..
    By celica-fiend in forum Tech and Conversions
    Last Post: 30-01-2006, 12:57 AM
