Results 1 to 8 of 8
Thread: 4agze only boosting 6psi with 165mm pulley
    N.S.W
    Default 4agze only boosting 6psi with 165mm pulley
    hey guys only recently my 4agze with the 165mm pulley on it which used 2 boost 10psi all day every day is suddenly only boosting 6psi. I hav checked for any obvious boost leaks tightening all hose clamps etc. Is it possible i am getting belt slip as the belt was replaced a few weeks ago, or could the charger itself be on the way out. The clutch is also engaging obviously, but wondering if these cluthces can slip. i know in some circumstances iv read on the forums clutches failing, but not half failing if u know wat i mean.
    help much appreciated
    Junior Member Grease Monkey bassy's Avatar
    Default Re: 4agze only boosting 6psi with 165mm pulley
    i know this might sound stupid but did u block the abv?
    bassy
    a new belt will stretch, so i would re-tension it for a start. also did you change the vacum pipe over on the ABV?
    N.S.W
    abv is by passed and it using aftermarket management. if the belt is slipping woulnt it hit 10psi and then say in the higher rpm wen it becomes harder to turn the charger slip then?
    unless ur sc clutch is slipping id say belt slip
    bassy
    N.S.W
    is there a sure way to tell if the clutch is slippijng. like i said it hits 6psi n holds it fine, doesnt belt slip usually occur at higher rpm
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Yeah,
    Belt slip is usually at the higher revs say above 5500 for stock 4AGZE.
    With a 'slack as' belt (i.e. completely loose) I could still get 10psi on my car, with the pullies sized for 18psi (SC14 conversion). Usually belt slip is accompanied by a sqwoooooooork sound when you try to 'rev through' the slip.. New belts will need to be re-tensioned very soon after installation (5 minutes of running usually) especially SC belts as they have a lot of load and they very quickly settle into the pulley grooves and get slack again. Even then, about 2 weeks on you will probably need to re-tension the belt again, then a couple months after that....then its pretty much good for a long time.
    YMMV - that is just my experiences with caning the SC14 on high boost.
    Regarding the sc clutch, does your car still make the same pitched 'whine' you are used to and does the pitch vary solidly with RPM? If so your clutch is probably ok.
    Cheers, Nick
    == 4AGZE SC14 Supercharged ==
    N.S.W
    yeh it sounds and even runs fine just that its only boosting 6psi.
    will re tension belt this arvo thnks guys
  1. 4AGZE pulley upgrades
    Last Post: 13-07-2006, 08:13 PM
  2. 4AGZE - EA Falcon Pulley Mod
    By TooF in forum Tech and Conversions
    Last Post: 15-05-2006, 12:23 PM
