Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 72
Thread: F series diff question
    Default Re: F series diff question
    Depends which housing you're talking about. If you mean an IRS housing, then yes it will go in with no modifications provided you use the right bearings. I have one in an RA65 Celica housing which was originally non-LSD.
    And in the live axle housing?
    We put MA61 LSDs in live F series centres with no issues. I haven't played with a true trac into F series live centre but I'd imagine should be OK.
    I'd have a search around - I'm sure someone did it.
    vic
    but the live F diff is fatter in the mounting of the crownwheel on the hemisphere than the alltezza , i did brief check with my alltezza diff and a live mx13 diif , didnt look like it would work
    Dave
    nuts Grease Monkey
    auckland
    ive been pointed to this thread so i'll add my bit
    G series (hilux) have a different crown wheel flange 4.77 and lower campared to 4.55 and taller ratios. is was told this by our diff shop at the time when i had a mx83 G315 fitted to a broken hilux G285.
    i've never seen any variation in axle size or crown flange in the F series so i'd be very interested in knowing (pics/measurements please) if there is
    to date i've sat the altezza torsen in a live axle head and the torsen carrier seemed to ever so slightly touch the end of the pinion gear. this due to a fatter lsd carrier maybe or that the side bearing shells weren't held tight to the bearings... dunno would have to complete the conversion. could we assume the altezza pinion gear to be a little shorter than the normal F series? dunno
    on the other hand i've successfully fitted a Kaaz altezza 2way in the F series live axle head. only issue i thought i had was the bolts holding crown wheel were not as recessed as much like the std F crown.. so the bolt heads stuck out more and when i sat it in the carrier looked like they'd touch the housing. i ground the corner out of the housing but when all fitted together.. found it probably wouldn't have touched anyway.
    this is a factory live axle F lsd from jdm cr30 masterace-surf 4wd van, the irs ma61/ta63/tt142 look exactly the same
    this is the altezza Kaaz fitted
    altezza torsen
    and when he gets round to it... a cusco altezza lsd about to be fitted into live axle
    http://forums.toyspeed.org.nz/viewto...50492&start=20
    oh and TRD list the same TRD lsd for ma61, mz11, gx71, ta63, crown etc as the altezza
    where i first twigged that altezza used a 7.5" diff
    http://trdparts.jp/english/parts_lsd_mechanical.html
    toyota lsd often require a shorter axle (T series, F series and G series)
    -Mark
    E2 + E7 fan
    Awesome, +rep!
    Junior Member Backyard Mechanic Wedged'86's Avatar
    Jun 2006
    Nice work man +rep
    Toymods Club Member Backyard Mechanic Big T's Avatar
    I can confirm that a true trac fits into the live axle MX13 F-series. They even use the same carrier bearings confirmed both by CBC bearings and seeing as i used the bearings Rabid-chimp sent me to suit an MA61.
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
    Jun 2006
    does the tru trac centre fit into the Fseries from a tarago??
    The full diff code is F282 if that helps.
    vic
    Id say yes but if yr unsure get a diff shop to check it for you.
    dave
    Junior Member Backyard Mechanic {Mr Crabs}'s Avatar
    Apr 2007
    Hi all
    Just a question im going to put a LSD IRS rear end From a MA61 supra in a TA23 but what ppl are saying a torsen lsd from a IS will fit a Non LSD celica?(RA60 or a ?? dont know the model but the ugly one with IRS) .
    I want IRS and a LSD and i have a cheep source for a MA61 or CELICA.
    [QUOTE=case]RA60 or a ?? dont know the model but the ugly one with IRS) . QUOTE]
    Do you mean the one that has a big square bit missing from where the lift back should be?
    SA63 or RA63 would be that one.
    (\__/)
    (")_(")
    Apr 2007
    Sa 63 non LSD sounds like the one
    [QUOTE=Steve M]
    Quote Originally Posted by case
    RA63/RA65 is the one, SA63 run t-series IRS not f-series.
    If in doubt power out
    Apr 2007
    HI
    Just want the best lsd irs to put in the old girl so the F series with a IS torsen LSD will fit a MA61 centre ?
  1. T & F Series Diff Repair Manual (inc LSD)
    Last Post: 16-11-2011, 09:20 PM
  2. Hilux Diff question
    Last Post: 25-09-2007, 08:19 AM
  3. g series diff into ra23 q's
    By SillyCarS in forum Tech and Conversions
    Last Post: 01-10-2006, 05:36 PM
