Results 31 to 45 of 72
Thread: F series diff question
    Default Re: F series diff question
    MA61 diff is already F series. There are a variety of LSD centres you can use in an F series diff - there's the factory 2-pinion clutch LSD, the Altezza/IS200 torsen LSD and the TrueTrac torsen LSD. I'd recommend the latter, it's much cheaper than the Altezza one and quite a few of us here are using them in MA61 diffs with good results.
    New Zealand
    It would pay to shop around on the Altezza centre, mine was only $280NZ so you might find a bargain.
    Callum
    vic
    I think i paid $850 for mine , a complete diff tho with 25000klm on it tho.
    dave
    Quote Originally Posted by case
    Hi all
    Just a question im going to put a LSD IRS rear end From a MA61 supra in a TA23 but what ppl are saying a torsen lsd from a IS will fit a Non LSD celica?(RA60 or a ?? dont know the model but the ugly one with IRS) .
    I want IRS and a LSD and i have a cheep source for a MA61 or CELICA.
    Aren't the MA61 diffs 1440mm?
    I hope you don't like you're current rims... You're going to have to run FWD offset rims if that's correct...
    ([][][]II--LT--II[][][])
    Junior Member Backyard Mechanic {Mr Crabs}'s Avatar
    Apr 2007
    From what measurement i made looking in to this with the rims ive got(suited for FWD car) i will have to roll the guards or it will scrape for sure. I machined up some spacers to match the width of
    an RA65 to bolt on to the T series diff as a guide.
    Just want to reduce my unsprung mass and improve traction and im not a big fan of the old live axel save them for 4WD's
    Adeladie
    So theres a 2way Kaaz LSD that will fit the Fseries from the YR22 tarago?
    Will fit with out too many or zero mods?
    N/A 3SGE KE70 on its way
    nuts Grease Monkey
    auckland
    not all lsd are the same obviously. some lsd may require axles to be shortened 5mm or so, mainly the factory toyota spring loaded clutch lsd which either have a big spring in the center (hilux lsd) or the two plates thru the middle pushed apart with 4 springs (T and F series).
    have just measured an ma61 F series lsd and altezza torsen.. both are 150mm to the outsides of the side bearing shafts
    -Mark
    E2 + E7 fan
  8. #38
    south austraila
    I have a jig, for the MX13 diff, to RA40/60.... & building a jig for the AE86, KE70.... as i have some one intrested, in one of my, MX13 diffs, to fit the AE86..
    The MX13's housing, will take the, MA61's LSD centre, & the RT142's disc set up ..
    Project: '82, GA61 XX
  9. #39
    Junior Member Backyard Mechanic Wedged'86's Avatar
    Jun 2006
    Just scored an F series diff today and the price was right ($0.00) Haha.
    Now to get a torsen LSD.....
  10. #40
    F series from what?
  11. #41
    Jun 2006
    Tarago, baby
  12. #42
    Do plan on sticking with drums?
    If you want to go discs, then find yourself an F Series from an MX13 Corona, as the ST141/RT142 disc brakes (from the live axle) are a direct fit...
    Sure, you'll have to pay for the diff, but it'll be cheaper than getting some caliper adapters made up... (Unless you're a fabricator by trade)
  13. #43
    Better again, MS112 diff has discs already.
  14. #44
    But, the MS112 diff is 1450mm wide, where as the AE86 (S Series) is 1410mm wide ust like the MX13 diff... (Of course, that info you already knew as you have in in your Diff Database... )
  15. #45
    Jun 2006
    I thought about sticking with the drums cuase the handbrake will bite better but i just couldn't stand seeing big ugly arse drums sitting in the middle of my 21'' chromies yo!
    (that was a joke PLEASE don't think i was serious)
    Nah i'm pretty handy but my dad IS a fabricator so i'm confidant we can make up some caliper brackets. I'll be doing a brake conversion before it goes in.
    I probably woulda gone hunting for the MX13 diff had i known that but you know.. the price for the tarago one was right....
  1. T & F Series Diff Repair Manual (inc LSD)
    Last Post: 16-11-2011, 09:20 PM
  2. Hilux Diff question
    Last Post: 25-09-2007, 08:19 AM
  3. g series diff into ra23 q's
    By SillyCarS in forum Tech and Conversions
    Last Post: 01-10-2006, 05:36 PM
