Results 46 to 60 of 72
Thread: F series diff question
  1. #46
    Default Re: F series diff question
    The ST141/RT142 rear brakes have an internal handbrake setup and will kill the handbrake thats on the MS112 diff...
    Internal handbrake is perfect for the dorifto...
    ([][][]II--LT--II[][][])
  2. #47
    Junior Member Backyard Mechanic Wedged'86's Avatar
    Jun 2006
    Ahh, and those are good brakes all around?
    I was thinking which brakes to use and those will be easy as to source.
    Thanks man.
  3. #48
    New Zealand
    Quote Originally Posted by twentyEight
    Just curious whats wrong with the MS112 handbrake? Got one in my KE70 ute but not driven on yet, still need to hook up cables etc so of its a pivot point issue I might have a play with it. From looking at it I will need to do something about the leverage ratios compared to how it was setup in the Crown.
    Callum
  4. #49
    Forum Sponsor Conversion King
    whats the difference between the 2. i havn't looked that hard at it yet but they look similar, unless its the lever setup that comes out of the backing plate that is different.
    linden
  5. #50
    User Conversion King
    NWA
    linden, they are the same
    hello
  6. #51
    I thought the MS112 was drum braked, which would make them alot different being that the ST141/RT142 rear brakes on the MX13 diff give an internally handbraked disc brake diff...
  7. #52
    NWA
    MS112 has a internal hand braked disc.
    the flange on the end of the axle tube is very different from the MX13/RA40/RA60/RA23/rt142 pattern
    hello
  8. #53
    New Zealand
    MS112 diff, have also seen disc brake setup in MS110 but not sure if it was factory as the other MS110 I checked was drum braked. Has massively wide bearings like other Toyota disc braked live axles.
    Callum
  9. #54
    Well, that's a totally different kettle of fish then...
    And looking over what I typed, I meant to say that the ST141/RT142 has an internal handbrake setup and will kill the handbrake thats on the Tarago diff that Wedged'86 got...
    It seems that I led myself down the garden path by typing out the wrong diff...
  10. #55
    Jun 2006
    Haha, that's ok man, even the most perfect of us make mistakes. (It happens to me on rare occasions too).
    By the way i'm loving the info. The second rebirth of this thread is just as useful as the first.
  11. #56
    south austraila
    As i'm building a few MX13 diff's, got some prices, & numbers, of bearing's used.
    Axle set :- 2053 kit = $34.62 a side x 2 = $69.24
    pinion seal :- M1067 = $3.87 x 1
    pinion front :- 30306 = $23.60 x 1
    pinion rear :- 32307 = $28.40 x 1
    centre bearing outer :- 17831 = $19.25 x 2 = $38.50
    centre bearing inner :- 17887 = $50.2o x 2 = $100.40
    Total = $264.01 +GST = $290.41 full set..
    cheeper centre bearing's :- NTN. = $15.60 & $31.80
    Total = $219.91 + GST = $241.90 full set.
    I have a jig, for the MX13 diff, to RA40/60.... & building a jig for the AE86, KE70....
    The MX13's housing, will take the, MA61's LSD centre, & the RT142's disc set up ..
    Project: '82, GA61 XX
  12. #57
    Junior Member Domestic Engineer Sprinterboy's Avatar
    I know this is an old thread,
    But did you ever make up that jig for the AE86?
    Interested to see how it goes if so, as i may change my mind from doing an R31 diff conversion
    Some excellent info in this thread guys +rep
    SprinterBoyAus on YouTube
    SprinterBoyAus on Facebook
  13. #58
    ive had a AE71/86 jig for about 2yrs, or are you asking GA61XX?
  14. #59
    the AE86 jig, you have PM
  15. #60
    NWA
    RA40 is supposed to be the same as AE86
    so GA61's jig should work
    hello
  1. T & F Series Diff Repair Manual (inc LSD)
    Last Post: 16-11-2011, 10:20 PM
  2. Hilux Diff question
    Last Post: 25-09-2007, 09:19 AM
  3. g series diff into ra23 q's
    By SillyCarS in forum Tech and Conversions
    Last Post: 01-10-2006, 06:36 PM
