Results 46 to 60 of 71
Thread: calling all you 5m-e speciallists! work this one out
  1. #46
    JZA61
    Guest
    Default Re: calling all you 5m-e speciallists! work this one out
    Quote Originally Posted by ed_jza80
    not just a brief eyeball of the engine bay
    lol yeh i know, finiding the time is a different story.
  2. #47
    Junior Member Backyard Mechanic sunkloto69@hotmail.com's Avatar
    if you are in s.a, will help you do it mate
  3. #48
    JZA61
    Guest
    sorry man im in qld thanks alot for the offer though!
  4. #49
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    For instructions on "changing the pressure plate" check out the TSRM (Toyota Service and Repair Manual) in the link below.
    http://www.cygnusx1.net/Supra/Library/TSRM/MK2/
    There is a massive amount of info in there including trouble shooting.
    It seem the pressure plate is refered to as the clutch cover in this document by the way.
  5. #50
    wanker Backyard Mechanic MS-75's Avatar
    Quote Originally Posted by JZA61
    ok back to 5m problem i noticed my water pump squirting water into the fan when revved upto bout 4500, got a new one on order. also the racq guy said that the front left wheel bearing needed replacing when i bought the car. is it possibly the wheel? i was free revving it today and couldnt feel the vibrations anymore, omfgWTF? so i dunno its a real head fuk.
    If this is happening then odds on it is the water-pump bearings that are shagged, and sometimes you will feel the vibrations, ther times not.
    When the shaft finally snapped for me, I was on the highway at 110kph. I felt a thud through the pedals, heard a wierd crunching sound, and all the charge/warning lights went off in the dash.
    I pulled over immediatgely and found the clutchfan/pulley/shaft snapped clean off the water pump jammed in the radiator.
    Not good.
    As soon as the pump arrives fit it up-otherwise the same will happen to you on your way to work.................
    [email protected], WSID, COMPAK ATTAK, MAY 2006
  6. #51
    still cant figre out where the vibrations are comming from though, i suspect the flywheel. can this be a symptom of a screwed up flywheel?
    The flywheel is a big heavy steel disc, there's really not much that can go wrong with it. Far more likely to be the pressure plate as indicated earlier. To inspect that you'll need to drop the gearbox, and by the sounds of things that's well beyond your mechanical abilities.
    I think your best option here is to take it to a mechanic. Driving your car every day while it's like this is pretty stupid, you WILL break something major sooner or later.
  7. #52
    Just taking a punt but could it be the Bellhousing cover in between the block and the bellhousing. It could loose where the block doesnt meet it??? Just a punt, haha.
  8. #53
    JZA61
    Guest
    yeh my waterpump squirts water out of it so il b changing that, i dont know if im prepared to go out and do this cause in about 3 weeks im starting the conversion
  9. #54
    Penrith BC
    uhuh...
    post a pic sometime in the first week of dec with the engine out of the bay for us...
    in the meantime, you mentioned a week ago that the water pump is wholly cactus, and this vibration (bad) continues uninvestigated.
    i suggest fixing this ASAP
    your conversion will take a LOT longer to get off the ground than you think. and youve already elluded to you needing this car as a daily driver...
    preventative maintenance my friend...
    ../delete/ban
    tech moderator
  10. #55
    Penrith BC
    and if you think im being mean, dont just listen to me:
    Quote Originally Posted by MS-75
    Not good.
    ../delete/ban
    tech moderator
  11. #56
    JZA61
    Guest
    yea i realize that man, i dont make enough money to do a conversion properly. so im getting a family freind mechanic to fit the 5m-ge or 6m-ge. i know its half assed but im not cut out for it and i know no one would help me out after reading what i write. lmao. neways i still love my supra and hope i can cruise with you guys still on your club days or whateva. im in the qld supra club and .. yea hope u dont think of me as an absolut cock muncher. cause im not i just jump at a chance. thats why i get all excited and shit when an engine is for sale and i think i can afford it........ hope u understand. neways back to topic, if neone knows if it is harder or much different to fit a 6m instead of a 5m-ge id like to know, thanks.
  12. #57
    5M-GE and 6M-GE are basically identical for the purposes of an engine conversion. Only the internals differ.
  13. #58
    JZA61
    Guest
    hey u know the 3 litre soarers, old skool boxy soarers. what engine did they have? the 7m-ge or the 6m-ge? cause i might (MIGHT) be getting one ralii cheap at an auction. im tlking dirty sanchez cheap. like 50 buks, its an old peice got smashed windows and stuff but if anyone wants saorer parts it might b cumming into stock soon. like lights and dash and seats and stuff. if i get it. if not there is a cressida there for sale aswell. an mx83 i suspect cause it says in the lot description "gold" and i havnt seen any gold mx73's onli mx83's. im open to corrections if anyone knows of a stock gold mx73.
  14. #59
    mz1x had 6m and mteu, mz2x had 7m's
  15. #60
    JZA61
    Guest
    Quote Originally Posted by ViPeR_NiPPleX
    whats mteu?
  1. Article: Torque / Work / Power
    Last Post: 02-06-2006, 01:03 PM
