Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 98
Thread: up the power on the 18r
  1. #46
    Junior Member Grease Monkey kylestyleup's Avatar
    Nov 2007
    Quezon City
    Default Re: up the power on the 18r
    Quote Originally Posted by timbosaurus
    Alrighties... Yes, the mods listed will certainly add HP to the old 18R.
    After all this, you will *possibly* have a 200hp motor. It will use a lot of fuel, need constant maintance, and possibly not last long. This is why we usually take a standard 250hp EFI, 2 litre, twin-cam turbo engine and bolt it into our celicas
    Timbo
    200hp is possible then... lol
    I was just aiming for 150hp and a 7000rpm.
    Machinist's labor here is very cheap so work is not a prob.
    Tuning and dialing in will be the problem and details on the cam profiles and that forged piston.
    I think I'll play around with with the stock till I come across with a hi-comp piston with the correct profile for the 18R.
    - Port and Polish
    - 48 or 44 dual Weber
    - 1.75 or 2" primary and 2.5" pipes
    - look for a good cam profile
    - good oil pump..???
    - engine balance
    - hardened valve seats - Can I go big valves?
    Will that do?
  2. #47
    Nov 2007
    Quezon City
    Hello again...
    I need your comment on this one.
    I don't know anything yet about cam profiles but I am just looking at it logically.
    Which do you thing will be better?
    I am planing for a cam reground.
    Option 1 - is to add lift
    Option 2 - is to add lift also but I think is mild
    Option 3 - is which I think is milder staying to the stock lift.
  3. #48
    Raastler Grease Monkey
    I would have thought the best way to get power out of an 18r would be to replace it ?
  4. #49
    Nov 2007
    Quezon City
    Quote Originally Posted by Matt-AE86
    Well. It is not only you who have said that. as you have read from here.
    Thread is "Up the power on the 18R" not "What is better than 18R?"
  5. #50
    Running it on the starter would be an improvement
    Friends
  6. #51
    You'll have to check this for accuracy however I believe the 22R-E Pistons are domed slightly, From what I understand they are the piston of choice for the stroked 18R-G.
    Simon
    Beige.... The new Black!!!
  7. #52
    Junior Member Grease Monkey glytch's Avatar
    Hey all this talking has spurred me to get a 44 Solex, manifold and cam. I'll let you know what the results are when I get them and find time to install.
    RA40 Coupe - Even more Turbo beating ponies.
    "Give a man a fire and he's warm for the day. But set fire to him and he's warm for the rest of his life."
  8. #53
    you found 44s? where?
  9. #54
    In storage It came off a Renault 12 about 25 years ago, and has been sitting in the old mans shed ever since. Hooray for cleanouts.
  10. #55
    Mud Mechanic 1st year Apprentice
    Aug 2006
    tas
    its been a long time in the making and lotsa $$$ spent but im finaly happy with the result.
    What ive had done
    block bored
    head plained
    hardened valve seats fitted
    mild cam fitted
    4-2-1 extractors 2in pipe with hot dog and dampener (sounds realy tuff)
    electric fuel pump
    electric dizzy with advance
    larger radiator
    32/36 webber
    Finaly the tonne of steel 4wd can move at a reasonable pace, its not no V8 powered monster but it still has some balls
    it only cost 3g with a workshop doing all the work.
    *If It's Not Toyota, Its Not Tuff Enough*
  11. #56
    Cool. That sounds pretty much what I have (and am in the process of doing) had a chance to tune it on a dyno? any idea at what power it is putting out?
  12. #57
    how much could you take of an 18r head? 20 thou be too much?
  13. #58
    20 thou should be fine. Just remember though that your already noisy timing chain will get noisier, and you may need to play around with the spring in the top timing tensioner.
    My experiences have been:
    manualise secondary in stock carb - gave far better top end, no extra bottom end torque
    Replace carb with 32/36 weber and add 2" free flowing exhaust - massive amounts of improvement across the entire rev range. No jet tuning was done, the carb was off a 2Ltr escort.
    Replace motor with 18R-G variant - massive improvement in accelleration, space time continuum bending ability, sound, and size of balls.
    Replace twin carbs with EFI - burnt out alternator and forever had problems until I realised what I did, even after going back to carbs.
    Replace motor with 18R-GTE rebuilt with CT26, new ECU, Electronic ignition, etc, etc - will let you know how it goes.
    What I would do if I were to try and get more out of an 18R-C again and wanted to keep it:
    Cam - lumpiest I could go
    O/S valves, and stronger springs
    EA foulcan throttlebody EFI onto modified manifold with MegaSquirt 2 ECU
    electronic ignition
    ARP rod bolts and head studs
    biggest overbore I could get flattop pistons for
    oval shaped head
    CT20 turbo on custom manifold
    lightweight flywheel with heavy duty organic clutch
    18R-G oil pump and winged sump
    That's just what I would do, and it would cost a lot more than the motor is worth. If I were to do it, it would be to say "Cause I could", and not be to try and have a power monster.
    I would say that there are only 2 reasons why you should try and get decent power from an 18R, first is that you just want to, and second is because you are not able to get anything else engineer approved/race homolgated. Doing it because you think it will be 'cheaper' is just stupid. Of course, if you want just a bit of get up and go so that mopeds stop overtaking you, then 32/36 weber, extractors with 2" exhaust, electronic ignition from a 21R, and a mild to moderate reground cam will be your best bang for buck, and shouldn't be too expensive (most of it can be done by a half confident backyarder with basic tools).
  14. #59
    I've got no noisy timing chain the tensioners havnt even done 1000 kays
    My problem with the 18r in the ra40 is the no 1 cylinder is 110 psi whereas the rest are 145
    the problem is defanatly not in the bottem end as i rebuilt it but i didnt reco the head
    I suspect a valve is damaged, but i'll be taking my other 18r head into work and i will strip it, acid bath it. surface grind it,face valves and one of the tradesmen will cut the seats for me
    So i thought while it has to be surface ground i'll try to get some more comp out of it
    Luke
  15. #60
    Junior Member Grease Monkey MitchE's Avatar
    Jan 2007
    about the 22R pistons if they are used to stoke the 18R out obviusly they are not going to fit as the pin height will be shorter.
    so aftermarket 18R pistons will be the only option.
  1. GUIDE - 85amp EA Falcon Alternator onto 18R or T series engines
    Last Post: 03-05-2019, 05:25 PM
  2. 5ME - no power ( less than usual :oP )
    By WA_TRD_83 in forum Tech and Conversions
    Last Post: 30-08-2006, 09:27 PM
  3. Article: BHP vs HP vs kW and other power conversions
    Last Post: 07-06-2006, 12:37 AM
  4. Article: Torque / Work / Power
    Last Post: 02-06-2006, 02:03 PM
  5. where to get power, but only when engine is spinning.
    Last Post: 26-03-2006, 09:39 PM
