The 4.5 is most likely from a hilux , When you say the bolt pattern is different do you meen the hole sizes are different or the holes don't line up at all , If the holes are a different size you can drill them out and use 10mm bolts but if the hole pattern is out just turn the flange 45 degree and redrill the holes in the pinion flange .
I;v done this many times .
Trevor
