Hey all,
Just wanted to know if someone could point me in the direction of where I can get intense specifications for the stock Australian AE86 Sprinter axle/diff. I know it's a S314, but I need more than that, I need bolt hole configuration, lengths, sizes, weight, everything. I'm going to go raid a few wreckers and find a E/F/G series but I need some stats to compare stuff to.
Can anyone help?
All I know so far other than what the axle code can tell me is that it's 1410mm long from drum to drum....
Any E, F or G series diff you find will need to be fully customised (all diff mounts changed) so it really doesn't matter much about the donor diff. Just get the series, ratio, brakes, stud pattern and length you want (if such a diff exists) then get the mounts swapped over.
And also I guess you already have a Sprinter, in which case you can always check under it with a tape measure. Or check a KE70/TE72/AE86 at the wreckers while you're there.
Hen
