Results 16 to 30 of 42
Thread: 1ggte single turbo conversions
    CROSSPLANE CRANK! Domestic Engineer Merudo's Avatar
    Default Re: 1ggte single turbo conversions
    Hah, all signs point to dealing with you in this turbo matter, huh...
    Maybe if I hadn't have quit my job things could have happened a bit quicker with this whole turbo business!
    Ah well...
    ^^ thats who im getting mine through
    vic
    Quote Originally Posted by love ke70
    oh, well thats handy isnt it...
    did you use a GT30R or GT3071R?
    because apparently the GT30R is a lag monster, and the GT3071R will spool 1000 rpm sooner...
    GT30R was the turbo i used, even then if the gt3071r would spool 1000rpm ealier, you would then be making full boost at 4000rpm as apposed to my previous 5000rpm. I would still go with the gt2871r. It really is plenty for what you would want.
    Junior Member Backyard Mechanic 1jzracing's Avatar
    Quote Originally Posted by Forcefed6
    Yes, 6boost make a manifold for a 1G. This is because each and every manifold is custom made to order. I am a 6boost dealer, but you can also approach him direct if you will.
    im doing a 1g conversion into my e30 bm at the moment and want to run a single
    so whats a single turbo manifold worth????
    do they do a stainless one???
    a fool remains undescovered untill he speaks!
    give 6boost a call
    www.6boost.com
    his number is on there
    dont think he does stainless, but why do you need it?
    the custom making of each manifold is great
    Toymods Tuner Backyard Mechanic Forcefed6's Avatar
    Quote Originally Posted by 1jzracing
    They retail from $1200 for a 6 cylinder manifold. Only made in in mild steel. Stainless tends to be a little unreliable with the extreme heats of a turbo setup, as stainless tends to expand too much and crack more easily.
    Z10 Soarer - [email protected] ... 11's soon
    CHECK IT OUT HERE
    Roll Ons? Carport Converter Endless's Avatar
    Proper manifold bracing on the exhaust side headers and a brace for the wastegate provision will reduce the chance of that from occuring.
    People that complain about cracking ebay stainless manifolds and such usually just have a bigass gate hanging off, with no bracing at all which causes it to crack over time.
    stainless so it doesnt RUST when its wrapped in glass lagging!
    im looking for light weight long branch stainless tube not a heavy steam pipe one
    $1200 is way over the top!!
    good luck finding one
    theres that pretty external gate hks stainless one on ebay, been up for a while now
    not much cheaper once u ship it here, and you have to do the external gate thing which will cost more
    and mild steel in your exhaust track doesnt usually rust...
    hes talking about wrapping it in the exhaust tape,....which i have been told does increase manifold life...increses rust.....
    but i could be wrong...just going by what i have been told,
    also what have you guys done with coolant fitting for the 1g,
    theres 2 out and 2 in, (2 out on the thermostat housing) and 2 just below behind the water pump,
    do you guys just block one of each of those fittings off? or are they too small to supply one larger turbo?
    my turbos not water cooled so both mine are blocked off, and ive got no cooling issues
    cheers steve,
    1ggte, 11.22 @122mph
    looking at the turbo i have the lines are about the size of one of the water lines, so i think it will be ok, if not im sure you could get a Y junction...
    Quote Originally Posted by hypo23
    ahaha yeah i noticed, i went thru all the pics i had in my camera fone, and looked at all the single concversions done,
    notixced you had tline blocked off
    lol!
    blake
    If you have a look at the pics on my website, it shows really clearly what I did.
    Basically I put one of the outlets TO the turbo, and the other INLET out of the turbo.
    THEN, I plumb the second inlet and outlet together, so they just flow out of one and back into the other without actually doing anythign.
    Facebook | LinkedIn
    cool bananas, all coming along well
    what have people done with all the oil returns? just blocked off the second entry on a stock one?
  1. **HELP** Twin turbo to single 1jz setup.
    By DLA11D in forum Tech and Conversions
    Last Post: 11-07-2011, 11:06 AM
  2. Single or Twin Turbo
    By Ashe in forum Tech and Conversions
    Last Post: 09-08-2006, 09:23 PM
  3. 1G Single turbo donor playoff
    Last Post: 23-07-2006, 04:26 PM
