Page 4 of 13 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 183
Thread: Turbo 5ME? (5MTE)
  1. #46
    Default Re: Turbo 5ME? (5MTE)
    The thread wasn't about whether or not I can do it or I should do it because this has been discussed before. It is something different that I haven't seen many people do (probably for good reason) but I wanted to see if it was possible and cheap just for the experience.
  2. #47
    Quote Originally Posted by MS-75
    Trust me,as soon as you get your first overflow bottle cappucino you'll wish you poked your own eyes out instead.
    LOL
    If I didn't think putting a quote your signature is silly, this would be my pick.
  3. #48
    Quote Originally Posted by gianttomato
    Whilst I'm prepared to accept a 5MGE makes about 90+ rwkW, 5MEs only made 120-130 hp at the fly (ie 90 kW at the fly). Factor in the usual 25 - 30% drivetrain loss and you've got the standard sort of 65 rwkW that we see.
    The MA61 5ME was rated at 103kW. Still doesn't factor into the figures, but given the minor mods on his car, anything is possible
  4. #49
    Junior Member 1st year Apprentice Cplus's Avatar
    London
    Quote Originally Posted by RObErT_RaTh
    possible yes.
    cheap? well, initially maybe. not in the long run though!
  5. #50
    Quote Originally Posted by JustCallMeOrlando
    So no one believes my dyno readout anymore?
  6. #51
  7. #52
    JZA80 Convert Backyard Mechanic
    LOL
    Hah, I'l do it then. Quote of the year
  8. #53
    I'll be sure to take a pic when I poke my eyes out to go with your sig
  9. #54
    wanker Backyard Mechanic MS-75's Avatar
    Seriously, yes it can be done cheap if you can get a manifold/turbo and dizzy from an MTEU, but the $$ come when you have to fuel it. Aftermarket comuter for safety=$$.
    Keep the boost below 10psi and it will survive. Just.
    [email protected], WSID, COMPAK ATTAK, MAY 2006
  10. #55
    Junior Member Backyard Mechanic sam-131's Avatar
    i plan on doing a 5mte to the soarer it'll cost me a 100 bucks all up keep the boost low and it should be right the bloke i brought the soarer off (dave) did the same convershion but on gas and it was lethal he tells me
    pffft aftermarket ecus just crack open the afm meter and give it a slight tune 5ms a dime a dozen
  11. #56
    Quote Originally Posted by sam-131
    And this will retard the ignition timing how?
  12. #57
    I was only gonna run it at 5-6psi
  13. #58
    it'll solve the fueling dramas the mteu's dizzy will solve the timing problem
  14. #59
    You're not going to find out if you like turbo's then. 5psi from a tiny turbo isn't even worth $1500 or whatever you were hoping to get this done for, let alone what it will actually cost.
  15. #60
    should get a cam reground and just wham it in for kicks... after all, its only a 5me
    Last Post: 11-10-2014, 12:02 AM
  2. Boost Leak Tester
