Results 1 to 13 of 13
Thread: removing door trim - help please
    1 alicia place kenthurst nsw
    Default removing door trim - help please
    Hi
    I have a broken window regulator and am trying to remove the door trim.
    All the screws are removed but I can't get the plastic trim around the interior door handle off - any clues?
    thanks
    Steve
    Junior Member Backyard Mechanic DLA11D's Avatar
    Default Re: removing door trim - help please
    On what Car?
    Sorry car might help
    ae101 Levin
    thanks
    Steve
    Have you tried sliding the handle out, the screw is only there to hold it in place.
    Did you take the door handle out?
    Not sure on your car, but normally undo the screws, pull/slide off to one direction, then you have to unclip the rods behind them that connect it to the locking mechanism
    I am the sun
    thanks Dale
    it is the door handle and the plastic trim around it that is stopping the trim from coming off the door.
    There are no screws holding the handle or the trim to the door that are visible - thats why I posted the question.
    thanks
    Steve
    Get a picture of it, I'm sure someone on here will have seen something similar enough and be able to tell you how it comes off
    I am the sun
    Lift the handle slide the plastic surround forward and off.
    Withdrawn... sleep deprivation induced stupidity
    draven u mean circlip ? isnt that on the window handles?
    some of the handles clip into the trim so just push them forward a bit and they'll pop out.
    right
    door handle
    yes, I meant window winder (I'm fried).
    AGE-16V Automotive Encyclopaedia Dimmy's Avatar
    yeh the circlips hold the window handles in place so all you do is use a flathead screwdriver and put it under the handle and either turn the handle (if you can) or just slide the screwdriver around
    The trim is usually held into the door with pressure clips after the screws
    I have been pruned by old man river!!!!!
    slide a cloth under the handle instead of the screwdriver save marking the trims.
  1. removing the manifold butterflies 1ggte
    By 1jzracing in forum Tech and Conversions
    Last Post: 03-10-2006, 12:23 PM
  2. Removing / Inspecting valve springs without removing the head - is it possible?
    Last Post: 16-06-2006, 02:58 AM
  3. Need help removing r154
    Last Post: 10-01-2006, 05:31 PM
  4. Removing z20 front bar
    Last Post: 05-01-2006, 10:07 AM
