Results 16 to 22 of 22
Thread: How much can i Showel the head, 18R?
    Bumble Bee Cross Backyard Mechanic sleepin22's Avatar
    Default Re: How much can i Showel the head, 18R?
    lol, thats not the plan(see my ra25 overhaul thread).
    oh... then rebuild engine with suitable valves and seats while you're refreshing the car.
    meh ... use PULP and when the engine wears out, put a 18RGUE in it ;-)
    That's NOT the answer he was looking for!!!!
    edit: Damn... he beat me to it
    FWIW - I ran lead replacement lube and premium unleaded fuel in my 18R for the first six months after it was back on the road after a rebuild. That was when I thought i'd never do a conversion and have to look after the engine. After having to adjust the valves countlessly as they were pulling through the seats slightly (despite the lube) and burning out a valve (think it was the dodgy tuning of the weber combined with exhuast mani leak) I just gave up and started running the cheapest fuel I can get and no LR lube. The car has been running nearly 2 years with no adverse affects whatsoever. I have no idea where my timing is set... If i hear it pinging i back it off a degree until next time I tune it
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    Lillehammer
    Hi again
    Thanks for all ur answers, i guess i will just have a looksee and see if its worth the effort, kinda sounds like its a waste of time.
    Turboing the 18R, hmm that sounds intresting, what needs to be done, and can it be done in a fairly cheap way? not intrested in throwing a lot of money at this engine, but a cheap turbo upgrade could be somethin.
    What kinda turbo, manifoilds etc would i need to use?
    Quote Originally Posted by MarkIIRx12
    it's all custom (intake & zorst) ... personally, i woldn't bother if i had the chance again. Has proven to be very costly and time consuming (for me anyway),
    Seeing as you're US based - i'd suggest a 22RE and find a turbo manifold (or make one). They're popular over you're way so parts and experience should be easy. You'd still have the issue of an ECU to run the whole show.
    Quote Originally Posted by timbosaurus
    ahhh, the good ol days of super. Are they trying to tell us something? indeed they are! they trying to encourage engine conversions in old cars
    south australia
    if it helps this is from the green book:
    fig 4-17
    if warpage exceeds the limit, correct it by machinging or replace the head.
    Head Surface Warpage Limit 0.05mm (0.0019in)
    Maximum Reface Limit 0.2mm (0.0079in)
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 11:36 AM
  2. Does 18R intake fit onto 21R head?
    By restorolla in forum Tech and Conversions
    Last Post: 14-09-2006, 09:05 PM
  3. 3s-GE Head gasket
    By SilverSt162 in forum Tech and Conversions
    Last Post: 03-08-2006, 08:44 PM
  4. Rebuild 18R cylinder head *with pics*
    By timbosaurus in forum Tech and Conversions
    Last Post: 15-07-2006, 04:10 PM
  5. Matching your head to your o-ringed block.
    Last Post: 09-05-2006, 02:14 PM
