I just removed the cam cover and manually turned the motor and from above all looks to work correctly!
Obviously the valve could be stuck below...
Whenever I have the car running or turning over, I have fuel shooting out of my no. 1 cylinder through the carbies!![]()
This seems to occur no matter where I have the timing!
My first guess is it's a bent valve... What else could be wrong here?
you're 100% certain the spark plug's working? cos it happened to me i had plenty petrol shoot out of both carbies till i got the right timing and it just fired up all good.Originally Posted by twentyEight
maybe a compression test would be wise
Checking the compression would tell me if the valve isn't sealing, wouldn't it?
yeahOriginally Posted by twentyEight
<ten charaters>
I really should've thought about that all by myself... <hits himself in the head>![]()
Ok... Looks like that re-build that I wanted to do is going to be pretty much straight up!![]()
Compression as follows:
Cyl 4: 116
Cyl 3: 136
Cyl 2: 146
Cyl 1: 0 (As suspected)
If a valve is stuck open, a good thrashing and heat cycling may very well free it.
And it should still start on 3cyls.
Also, when I took out the spark plug for cylinder 1, there was oil on the electrodes...
Maybe I'm incorrect, but this is not how it should be!![]()
Oil, or mucho fuel ?
Get it running, then diagnose the problems.
also the shim clearences on that cyl could be way off check 1st. from memory inlet is 9to 13 thou on base circle and exhaust is 11to 15 thou ,as if you have 0 clearence you will have 0 compression been there done that
get it hot and it will hopefully free it up a little atleast so you can get some compression, when it is hot try a wet test (put a small amount of oil in all cylinders before comp test) and see if the results are any higher. if results are higher then you would be looking at rings, and i not than it is probably a head problem.
sam.
