Results 1 to 15 of 18
Thread: WOLF 3D/V4 guru wanted (one small hint needed)
    BOTTLE FED 1st year Apprentice madrolla68's Avatar
    Jun 2006
    W.A.
    Default WOLF 3D/V4 guru wanted (one small hint needed)
    I have mine all installed and running on my K series turbo setup, but am having trouble connecting to my PC to tune it realtime.
    PC cant see ECU etc.
    Any hints would be great.
    Add Lightness! Grease Monkey spectral's Avatar
    Default Re: WOLF 3D/V4 guru wanted (one small hint needed)
    I had more luck setting my laptop to use the following port settings;
    9600 baud
    8 data bits
    No parity (N)
    1 stop bit
    rather than the 38400 baud that the Wolf manual specifies.
    Jun 2006
    W.A.
    Quote Originally Posted by spectral
    9600 baud
    8 data bits
    No parity (N)
    1 stop bit
    Ok thanks ill try that, cause no matter what i do i cant get the ONLINE OFFLINE buttons to see the ECU at all.
    What buttons on the software do you click on too connect with the ECU>
    The software automatically connects. You have to have the ignition on before the ECU will connect to the PC. The engine doesn't have to be started though.
    Also make sure you are using the right Com port if your laptop/PC has 2 of them.
    Jun 2006
    W.A.
    NAh it doesn't have com ports it only has USB ports.
    So if the power light is on the ECU it should recognise it ey.
    ?? My Wolf 3D V4 had a serial cable, not a USB cable.
    Even the new Wolf 3D V5 has serial
    Jun 2006
    W.A.
    Yeah i know si had to get a serial to USB adapter cable.
    MAybe thats what is wrong ey.
    yeah most likely. you'll need to find a way for the USB adaptor to interface with the Wolf software which is looking for a serial port, not USB.
    Try this (from the Wolf support page)
    The most common problem people have when they first install their USB to Serial Adapter is that they need to match the COM Port Assigned to the adapter to the Wolf PC Software. If the COM Ports are not identical, there will be no communications between the PC and the ECU.
    To determine the assigned COM Port for the USB to Serial Adapter:
    Click on Start
    Go to Settings
    Go to Control Panel
    Double click on System - a dialog box will open
    Click on the Hardware tab
    Click on the Device Manager button.
    Ports (COM & LPT).
    Select the USB to Serial Adapter that you have just installed.
    Right Click on it.
    Choose Properties.
    Choose the Port Settings tab.
    Click on the Advanced button.
    Make sure the COM Port selected is the one you want to allocate the USB to Serial Adapter to.
    Click OK.
    Click OK.
    Close Device Manager.
    Jun 2006
    W.A.
    Yeah i did that shit man,but it reckons that COM 6 is the port for the USB but it has three USB ports and i dont know how to work out which one to use.
    the driver software for the USB -> serial adapter should allow you to change the COM port that the pc sees the serial port on. You should set it to something that the Wolf application can connect to (this is how i do my old old haltech to my laptop, and it works)
    what usb to serial cable to you have?
    if its the same as with the microtech only 2 brands will work with it
    belkin and some other one
    KE38 - 2TG
    MS65 - 1UZ
    Junior Member Backyard Mechanic 1jzracing's Avatar
    i had a similar problem with using a usb-serial adapter but i just ahd to use a different com port an it was all good, make sure you set the same port on the ecu as the laptop, ie set the wolf to com3 for eg and make sure the lap top is set to use com3 for the adapter etc
    make sure you use the software that comes with the adaptor cable too
    a fool remains undescovered untill he speaks!
    Jun 2006
    W.A.
    Quote Originally Posted by 1jzracing
    Thanks for all your help guys, the cable did not come with any software and i have tried changing all the COM ports to match the laptop as the wolf software goes from COM 1 to COM 10.
    Jun 2006
    W.A.
    Quote Originally Posted by madrolla68
    I eneded up using my hand controller to tune it ,bloody long winded but now i need to fine tune it and CANNOT get this bloody thing to connect still.
    I connected it to the work laptop that has a serial port and bingo it works fine.
    Any more hints on the USB to serial saga fella's please.
    has no Toyota anymore :( Conversion King tooch's Avatar
    Yeah some of the USB/Serial adapters are incompatible with the Wolf, you can buy one that works from the Wolf online store, but it is kinda exxy for what it is.
