Results 16 to 19 of 19
Thread: removing the harmonic balancer on 1jz
    Default Re: removing the harmonic balancer on 1jz
    FYI (just in case you've never used a puller or only used it on other engines) Screw in the main big bolt into where the crank bolt came from. You don't need to go all the way in, in fact it's better if you dont. I've been told that over tightening it (screwed all the way in) could possibly damage the crank.
    Screw it on enough that it will hold firmly, about 5+cm's. Screw the main 'puller' piece onto the main bolt that is now hangin out of the crank. Screw it on enough to have full thread contact, thats it, no more. Grab two long bolts, thread on washer. Thread through the top and bottom holes on the main puller (one at a time) then into the pully. There will be 4 holes. Two with thread, two with out. Best to test which before you get this far and test which bolts fit the threaded holes (if you get a universal kit).
    Basicaly all you do now is tighten each of the bolts in turn. Tighten top bolt, tighten bottom bolt, tighten top, tighten bottom, etc, etc. tightening the two bolts will pull the pully off. Whahlah, removed.
    Malicious
    voila, but close
    Fine then, EUREKA!
    Malicious
    Canada
    Quote Originally Posted by barned01
    are you sure about this 'park' thing, .
    As mrshin mentioned, park will not prevent the engine from rotating on an AT car.
    Park mechanically locks the tranny tailshaft. The transmission and torque converter have no fluid pressure, so they are not functional.
  1. harmonic balancer blues
    By SIKPUPY in forum Tech and Conversions
    Last Post: 15-05-2007, 09:41 PM
  2. Removing a 1jz manual box
    By IRB20 in forum Tech and Conversions
    Last Post: 18-06-2006, 09:03 PM
  3. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
  4. harmonic balancer ??? !!!!!
    By 1jzracing in forum Tech and Conversions
    Last Post: 04-04-2006, 01:30 PM
