Results 16 to 30 of 31
Thread: 3SGE + SC14 It begins
    wa
    Default Re: 3SGE + SC14 It begins
    Was thinking of doing this myself with my 3sge, would be interesting to see the power curve
    Sweet as Suede Domestic Engineer visions162's Avatar
    New South Wales
    hey mate could u post up diagrams and stuff on how and where u mounted it.
    Daily: 2006 Suzuki GSR 600
    Weekend: 1986 Celica Sx with 3sgte Gen 2
    Track Weapon: 2001 Honda Cr 250 Castrol Built Race Motor
    cruisin in a z30 Automotive Encyclopaedia -=DV=-'s Avatar
    wow a few years ago i was going to start this with a 4th gen sx...i had the blower, piping, ecu, injectors, EVERYTHING sitting in my spare room ready to start work..then i blew up the 3s the day before i was gonna start...and eventually i sold everything bit by bit to fund a monster 3s rebuild....and that engine lasted all of a few thousand ks ..damn cars....*goes emo*
    good luck with it man..DEFINATELY interested to see how it ends up..as its something i have always wanted to do from day dot
    JZZ30 Soarer
    wow....only one toyota now, at one point i owned 6....whats happened to me :S
    wa
    SC14 weighs 3.8kg FYI
    interesting idea, rep for oringinality
    My Corolla ! - 4AGTE
    KP61 - 4AGE
    Quote Originally Posted by Adsport
    thats not much! about the same as a nissan 4 pot caliper, and 2kg less than a GT4 caliper
    User Conversion King
    NWA
    you could always have 2 TB's, one before the SC and bypass . mechanically link it to the main manifold TB.
    stage it so the pre-TB is slightly more open then the manifold TB
    hello
    NWA
    electronic sounds good but the wolf mighten have the flexibilty to open/close it under every condition you require
    hello
    Tasmania
    an SC12 weighs just under 11kg, the sc14 would weigh more if anything.
    Any ideas on mounting positioning at this point?
    I was pretty much going to have it switched by load, probably not under a certain temperature and only. Cant think of any others at the moment, might even rig up a switch as well, so I can permanantly turn it off or something, which would then allow me to switch maps on the wolf for best fuel economy.
    (\__/)
    he is gaining support
    wa
    you should at least have the s/c on its own circuit with a relay. now, you can use a 12v source to trigger the relay and have it running fulltime or you can do a load switch using a variable voltage switch hooked up to your TPS, so that when you get a certain voltage feedback from the TPS ( X-volts @ -% ) the relay for the s/c is activated.. then you can use ANY ecu you wish cos your s/c is controlled independantly. from monitoring my GZE it usually clicks the s/c relay in at anything above 18% TPS in any given RPM
    KP61 - 4AGE
    I have already got a wolf running my 3sge, so the ecu isnt the problem. I was thinking a 3 way switch running a relay, always on, switched by the ecu and always off. The next issue is getting a valve thats really large.
    (\__/)
    NWA
    go to a gas or irrigation place and see if they sell a big enough solenoid valve.
    hello
    Jun 2006
    Run a small electric solenoid to supply signal pressure to a big wastegate valve.
    regards
    Jon
    Quote Originally Posted by jonra23
    regards
    Jon
    Interested in this idea, how would this work, how do you trigger a wastegate?
    (\__/)
    Jun 2006
    A wastegate in a turbo system is normaly just triggered by inlet manifold pressures where it controls booost pressures by wasting exhaust gass volume around the turbo.
    IF you wanted to control a valve electronicaly you can ciontrol the signal line pressures with an electronic solenoid as in an electronic boost control system.
    What are you trying to achieve with the valve that you are looking at running?
    regards
    jon
  1. twincharging prototypes needing constructive critisism (SC14 + turbo)
    Last Post: 11-10-2014, 12:02 AM
  2. my SC14 fitting guide
    By Adsport in forum Tech and Conversions
    Last Post: 05-01-2011, 11:04 PM
  3. ST162 3SGE Swap (Photo Diary)
    By buck naked in forum Tech and Conversions
    Last Post: 07-10-2007, 10:38 AM
  4. Simple 3sge Mods
    By Lonewolf in forum Tech and Conversions
    Last Post: 18-02-2006, 01:47 PM
