Results 16 to 30 of 43
Thread: WTF, my brake pad fell out, ***happened again, cressida PROS wanted***
    Default Re: WTF, my brake pad fell out, this may be an important lesson
    Quote Originally Posted by madmont
    I had a brake pad slip out on my Mazda RX2 some years ago. I think it was a combination of the pad being almost worn out and the disk being worn as well so the moral of the story is keep your pads and disks in good condition.
    hm.. being an older car, the first thing i did when to ours was slotted discs, new pads, new master cylinders etc etc.. same with the rears, new drum shoes, new cylinders etc..
    the first thing i check when buying a second hand car is the engine for oil leaks and stuff.. the second, is always the tyres and brakes.. having avoided a few dodgy buys when i noticed the pads worn out and the discs paper thin..
    i was once hit by an older woman driving a old corona.. her brakes were squeaking like mad and everytime she braked, the whole front end tilted over but she wouldn't stop, was pumping like mad.. anyway i drove faster to avoid her.. and next thing you know at the intersection to the freeway she bumps me... and she was going on the freeway too..
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    Quote Originally Posted by ViPeR_NiPPleX
    LOL dosing.... what will they think of next uleh.
    http://www.youtube.com/watch?v=csJEPzyj3dw
    Teh dose can be dangerous
    It would seem that GT has been prescribing himself some pretty hardcaore shit for the last week or so! Perhaps the WA crew has fundamentally changed him after their visit?
    Before: Stalwart, technically minded Toymods contributer
    After: Thread spamming, LS1 loving, dose afficianado
    Maybe GT is road-testing material for an australian version of Scrubs?
    Is not a good Backyard Mechanic GtiRboy's Avatar
    N.S.W
    Quote Originally Posted by gearb0x
    chuppa duppa doo doo
    Mmmmmmmm 2ZZGE
    N.S.W
    you HAVE to listen to that tricky muzzas song on that myspace site..omg bro
    Mmmmmmmm 2ZZGE
    Link us up uleh
    Here's a dose of da best re!!
    http://www.myspace.com/DIXIEEEE
    Then listen to "It's tricky muzzas" or "Electrodose". OMG uleh, it's like I'm the backseat of Habib's VLT!!! Zuuuututututu!!11
    Dude you know I have only added to this thread otherwise it would have been full of the other Rona's tall stories about 1JZ powered 150 kph runs on public roads to catch up to the 18RG Chariot.
    Parody video LOL! The guy who lost control in a straight line cracks the sads in the viewers' comments section below.
    http://www.youtube.com/watch?v=A2hfUcK1Akk
    Quote Originally Posted by allencr
    I don't know what you've got, but I've never seen any design
    that was totally dependent on the anti-squeel/rattle shims/clips to retain the pad. They usually are 'extras' only and aren't there to 'push the pad away from the rotor when not being applied'.
    I think you've got another problem - wrong pads or wrong caliper & bracket. They should never be able to drop out unless worn out completly, plus a VERY worn disk.
    i dont have problem, the previous person to install the pads was a cock head, all fixed now
    The boobs are back
    Junior Member Backyard Mechanic rob1's Avatar
    Tas
    baahahahahahahaha! Fcuk me drunk.........BOV, AKA Panpipe!
    happened again
    after much rooting around, i noticed that my rotor sits toward the back of the caliper spacer on my brakes, as u can see the gap toward the ouside is enough for my pads to fall out.
    whats causing my rotor to be off center,
    apparently its supposed to have the JZX81 brakes on it, could he have put on the jap calipers or rotors ONLY, making everything off set
    The boobs are back
    Default Re: WTF, my brake pad fell out, ***happened again, cressida PROS wanted***
    u should really be using the pads that are meant to go with the callipers..
    how exactly is the pads coming out? is it sliding through the gap? or just popping off the caliper itself ? have a bit of a hard time imagining this.. pics from the side?
    Vios - the metal back of the pad has tabs that sit on the lugs to the left or right of the gaps identified by phil. Once the outside pad has worn down enough, the lugs no longer sit on the tab and that pad falls out.
    phil: looks like you have the wrong disk - it should be centered between thoose two points. calipers mounts look like there are no spacers.
    From memory the JZX81 discs are a larger size then the MX83 stock discs, and therefore the caliper bracket has longer mounting lugs than the MX83 caliper. However, this should not affect the placement of the disc in the relative Z-axis. The part of the bracket which you picture there does not necessarily need to be centered, as the caliper mounts off the rubber booted lugs at the right of the picture, making it offset to the right (back of disc) and therefore centered.
    Take the disc off and measure the height. Compare it to the height as specified on the DBA catalogue. Should be 256 mm diameter, 68mm high and 20 or 22mm thick.
    By The Witzl in forum FAQ
  2. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
  3. Brake upgrades for FWD/AWD 5x100
    Last Post: 06-09-2005, 11:38 PM
