This is what I suspect - there must be some sort of mismatch. It is just very easy to measure up the rotor seeing as it is there on the car already. Whilst it is important to see what the thickness is (the reason I specify either 20 or 22mm is because there are two different specs for the MX83), you also need to check the rotor height, which for both types of MX83 rotors is 68mm. You may just have 20mm thick rotors where you should be using 22 mm ones - this would give you the 2mm outboard shortfall that is causing you grief. I have no idea what the JZX81 rotor height is but maybe you could get someone to check it for you or track some down from a halfcut.Originally Posted by Mos
If it's all too hard, just do the BA Falcon rotor - Nissan 4 spot caliper conversion and be done with.
