Just the measurements at the port opening. I heard a rumour that the port was a dramatically different shape to accomodate the injector, but I wanna know if this is just a rumour.
i will be going back to work soon, where exactly did u want dimensions {exactly}
The boobs are back
Nikita the RA23 is almost finished.
there is a relief for where the injector goes, but thats it really
The boobs are back
Sweet. If it becomes a problem, I'll just make a new releif on my 210 head... I'm designing and building my quads and testing them on my current motor before going to the effort of tracking down 88270 bits and building the bombproof motor.
if u have a special alloy grinding bit, its only about 8mm high and 13mm wide, but MANY ppl run the carby head and its never a problem, cant hurt to grind one in there tho
The boobs are back
I can't help but think it will help with better atomisation, especially at cold start when fuel tends to condense on the port walls. I wonder how much of this pocket would be left after serious port work? When you had your head ported, was it mainly changing the shape and angle of the port, or was a lot of material removed?
i cut my own injector releifs on my 88253 head with a round file..... dodgy, but it works!
I reckon this is the direction I'll take... I can't be stuffed swapping a head I don't have onto an engine I won't be keeping... Bank balance says no way man!!Originally Posted by The Witzl
main word: works
thats all that matters, the releif is all but non existent on my motor after the port job![]()
The boobs are back
Originally Posted by tricky
tricky, if you are seriously interested in doing a half descent job of this. I can send out a cross section of the head for you to borow and then you can make your own assesement.
PM me.
Hi Jeffro
just wondering if you ever tested these heads yet?
Was there a differemce between each head?
Karey
Originally Posted by jeffro ra28
I've tried searching but to no avail so now i'll ask what is an injector relief?
- LeeRoy
They never got tested because i canned the idea of using an 18rg as my engine of choice. I am currently selling all left over 18rg bits and peices, which consists of 2 fully reco cylinder heads, one with brand new valves and valve springs.
I guess they are talking about that circular shape on top of each intake hole:Originally Posted by LeeRoy
Hi Pilot ,i'm just wondering..the red colour fitting at fuel pump cover is for what?Originally Posted by pilot
megat-
1976-RA28 Cicely mosquito LB2000GT
