Results 61 to 75 of 86
Thread: super charging 18RGEU
  1. #61
    Old Fart Backyard Mechanic dale30's Avatar
    Casino nsw
    Default Re: super charging 18RGEU
    Sorry could only get one shot before battery went flat,now trying to find cable for computer.. will get new batterys and get some pics tomorrow.
    Bottom pulley was 2 belt 18r then i found a 5PK bottom pully 557mm circ at the wreckers.
    i got the inside of original pully turned out so new one was a tap fit into it then welded in place.
    waterpump pulley was a power steering pulley from a hyundia
    i cut of the shaft and got the inside turned out so it slid over the original waterpump pully.
    Truing this up was easy but it pulled from the heat when welded so i had tokeep rotating it and true it with hammer and punch.
    Mounting bracket is a piece of 25x25x3 rhs welded to the left hand engine mount pionting forward with 2 mounting tabs from 10mm flat welded to it for the bottom supercharger mounts.
    top mount is just a piece of angle bolted to the head and another to top sc mount with a piece of threaded rod and a couple of nuts to adjust belt.
    Had to cut the sc14 outlet in half and rotate 180 and reweld so the bend pointed up towards the inlet manifold.
    I have a 350 holly on top the sc14 with 64 main jets
    Belt runs true, Pumps 7.5 psi and drop back to 17" vaccuum at idle..Couldnt hope for any better. Idles like a shopping car. Should be very drivable and reliable with low boost.
    Gave it a rev and spun just over 10,000 easily....
    Purrs like a kitten but it will scream when i punch it.
    Will gladly explain it all on the phone to anyone interested.
    XT130 speedway car XT130 road car
    2 x Renault Fuego speedway cars
    02 TS50 falcon
    Light travels faster than sound. This is why some people appear bright until you hear them speak
  2. #62
    Casino nsw
    Need to think about timing settings.?
    Dissy was rebuilt and graphed to reach max 24 @4500 + 12 static = 36 total.
    I think this should come come down now with sc.
    Anybody thats turboed or supercharged one of these got any input please.
    02 TS50 falcon
  3. #63
    my old low-compression 18R turbo was
    ~20 degrees at idle (with vacuum port connected)
    max mechanical advance of about 10 degrees @ 3000 rpm
    it might pay to look for boost-retard dashpots at the wreckers and adapt to the 18RG dizzi.
  4. #64
    Hey dude off topic, but whats the TS50 like? I am in love with them and they have finialy come down in pirce enough.
    (\__/)
    he is gaining support
  5. #65
    Casino nsw
    Quote Originally Posted by WindeX
    Dont know about price but its got 130000 on it now and it still drives like a Brand New car..
    And looks cool.
    02 TS50 falcon
  6. #66
    Casino nsw
    You'll need a shorter filter (2JZ-GTE filter fits nicely), or do what I did and use a remote oil filter adapter.
    Any idea on part number ..repco just looked at me blankly..
    02 TS50 falcon
  7. #67
    tasmania
    i think it's z148 or z154, something like that. i believe they are like a z9 only a lot smaller
    any pics yet?
    are you sticking with the 350 holley or going bigger? i think a bit bigger would be better.
    beer me!
  8. #68
    Quote Originally Posted by dale30
    I just go to Supercheap/Autobarn/whatever and flip through the oil filter catalog. I wouldn't bother talking to any of the monkeys behind the counter.
  9. #69
    Nay sayer Domestic Engineer Mr Ed's Avatar
    May 2006
    2JZ-GTE filter = Z418 (or V022 i think)................suprsingly the same as my remote filter thing that came on the car.
    I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
  10. #70
    Casino nsw
    Gave it a bigger rev last night and tacho span to 10200. Thats Scary.!!!
    Spark plug choice will be important...Cant find out what standard was and i will need to go one range colder.Any recomendations
    02 TS50 falcon
  11. #71
    For future reference. But to save you the trouble the 18R-G use BP6EA (NGK that is).
    P.S 10200RPM... Very cool as long as it doesn't go bang!
  12. #72
    tasmania
    i'm not sure what plug, but the manual says the standard gap is 1.0-1.1mm
    beer me!
  13. #73
    Hey everyone, im a newbi to the forum. I dont know much about force-feeding the 18RG but just thought i would let you all know that if your got a bit of spare time and a bit of knowhow (and low on cash $) its not to difficult to set up your 18RGEU with the old (but fully programmable) GM Delco ECU. You can pick up a loom & ECU for less than $100 at a wreckers (JE camira) and get all the sensors fairly cheap. The only real difficulty is adapting the Camira Ignition module to the 18RG. Give us a yell if you want some info.
    Anyone else had a go at adapting the Delco ECU?
    Corona with 18RG-EU, Grandpa Beige colour (sleep)
    Running GM Delco ECU...Yep
  14. #74
    tasmania
    Quote Originally Posted by Svarky
    AAARRRGGGHHH!!!! yes please
    beer me!
  15. #75
    Casino nsw
    Bugger..
    Wish i had of known that 2 weeks ago when i started this.Will get one from wreckers and have a play.
    02 TS50 falcon
  1. 18RGEU conversion help
    By dale30 in forum Tech and Conversions
    Last Post: 01-11-2006, 07:06 PM
  2. super charging 22-re
    By Mattrt142 in forum Tech and Conversions
    Last Post: 02-02-2006, 06:39 PM
