Results 1 to 11 of 11
Thread: w55 help
    Junior Member Backyard Mechanic kugzs's Avatar
    Default w55 help
    http://img157.imageshack.us/img157/4663/zzzzhl4.jpg
    how do these clip together?
    thanks
    Got good condition 23/28 bonnet hinges? pm me
    Default Re: w55 help
    fit the fork to the bellhousing first. then slide the thrust bearing over the shaft. slide the clips onto the tags of the thrust bearing so the bearing and fork are locked together.
    Is this how the clip is meant to go on?
    http://img219.imageshack.us/img219/49/yyypp3.jpg
    in that pic, flip the clip around horizontally and you have it ( i think! )
    cheers vn.
    anyone able to confirm?
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    In the first pic, the clip on the left is the wrong way around (should be like the one of the right). Like ^ ^ ^ said, flip and should be fine. Then put the fork and check to make sure it won't come off.
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    In the first pic you literally just need to turb the bearing round and slide it on the fork and thats how it goes. All the clips appear to be round the right way and youll be able to see which side of the bearing it meant to interface with the pressure plate.
    - LeeRoy
    okay just want to double check that the bearing and fork are the right way around.
    http://img182.imageshack.us/img182/3...bearingsr2.jpg
    thanks
    SYD
    looks fine by me, just make sure the fork is clipped onto the nipple pivot point properly.
    Yeh looks good Kugs, you just need to slide the bearing onto the shaft properly and apply a little grease to keep its movement unhindered.
    - LeeRoy
  1. W55 into MarkII rx12?
    By MarkIIRx12 in forum Tech and Conversions
    Last Post: 09-08-2006, 06:21 PM
  2. What Clutch Slave Cyl for 4AGZE with W55 ??
    Last Post: 16-05-2006, 11:33 AM
  3. w55 speedo cable
    By MarioM in forum Tech and Conversions
    Last Post: 06-02-2006, 08:04 PM
