Results 1 to 10 of 10
Thread: No Spark on a 929
    capalaba
    Default No Spark on a 929
    I know this is not toyota related but I need some help and the madza forum is crap..
    Wifes madza 929 1991 stopped dead is morning in traffic
    Its turning over ok but no spark to plugs,replaced coil, igintor and other thing near coil (small square compenent sits on coil bracket) . but still no go does anybody have any ideas ???I have checked the relays I could see in engine bay 3-4 of them look ok and also check main fuses. Battery has full charge.
    Default Re: No Spark on a 929
    start from whatever detects the rpm signal, and then work backwards...
    not knowing anything about them at all, either the rpm detection is dead, or the signal from it to the ECU (or ignitor if no ECU) is dead, or the igniter is dead, or the coil is dead.... or there is a loose wire somewhere, so get out the multi and make sure you have both voltage and earth where you think they should be...
    you could even try reseating stuff that earths to the body perhaps..
    small square thing is balast resistor?
    check voltage to coil. check voltage to ignitor..
    it has a dizzy? check it is ok, and still turns adn so on...
    capalaba
    after looking further it seems not power to coil not the coil itself i will have to call in a professional am out of ideas...
    It hasnt broken a timing belt? If dizzy drives off one of the cams and they arent turning the dizzy isnt turning either..
    The small thing next to the coil is ceramic with a metal coil underneath? As stu said thats the balast resistor. This will drop the voltage to the coil.
    Piss it off and get a non resistive coil (usually a gt40 not gt40r for example).
    Anyway, this should have power to and out of it. But being efi (guessing since it's 91) is probably an ignitor. Check power supply to ecu, is fuel pump running? if not then you probably have a power supply problem higher up the chain.
    Friends
    the inept Grease Monkey Thomas's Avatar
    Is it the V6 model? The Mazda engines of this era in V6 form are notorious for ignitor / distributor problems. I know because my last V6 mazda's coil packed it in while driving it home after handing over cash for it.
    capalaba
    Yeah its the V6.. I replaced the coil and ignitor with a 2nd hand from wreckers maybe I got another dud one ?
    Anyway I will get towed to Auto Sparkie and see how we go.,,, Just know its nevet cheap
    Definately sounds like a supply to the ign system problem then. Shouldn't be too expensive, as long as your original or replcement ignitor/coil are ok.
    Friends
    vic
    they run the igt and igf system like the toyota , you could check the ecu stored codes
    D
    capalaba
    Well in turns out the Timing belt packed it in..
    The mechanic was nt sure if this caused bent valves and generally rooted head or vice versa.
    Anyhow the car is now for sale.....
  1. Wasted Sparks VS Sequential Spark
    Last Post: 08-01-2018, 12:19 AM
  2. Bigport 4age spark problem
    By Spode in forum Tech and Conversions
    Last Post: 24-07-2006, 07:40 AM
  3. Bosch Super 4 spark plugs- what do u think
    By skelz in forum Tech and Conversions
    Last Post: 12-06-2006, 11:48 PM
  4. Spark Plug Question
    Last Post: 22-05-2006, 08:09 PM
