Results 16 to 23 of 23
Thread: power steering lines-single or double flare?
    Forum Sponsor Backyard Mechanic Soarer21's Avatar
    Default Re: power steering lines-single or double flare?
    Quote Originally Posted by YelloRolla
    To me it appears to be a double flare. I am looking inside the flare at where the straight tube meets the flare and at the top (as edited "according to what I can see'). But as you said you have the part.
    I have been wrong before, and chances are I will be wrong again. Splitting it vertically would show whether or not is double flared (enough for me to see).
    I also agree that if the material is too thick to double flare, then it is more likely a single flare.
    The most important aspect of the double flare (from my experience) is with the design of the nipple/tube nut to get in far enough to seal, some nipples have the first few threads turned off to be able to achieve this. I recommend tightening the nipple in by hand and seeing if there is any movement in the pipe, if the rattle around like a dick is a sleeve, then it most likely needs to be double flared. The relevance of what is [I]needed[/] does not hinge on the part that you have in front of you.
    The relevance is the original question posed by the person at the top of this thread. Does he need single or double flare. Toyota used single, so theres your relevance. And for your satisfaction I have a spare pressure hose off an LX90 here that I will cut up later today.
    I'd rather have a bottle in front of me then a frontal lobotomy
    I am not trying to prove you wrong, I am happy to be wrong, nor am I trying to rub you the wrong way. I even think that my Cressida may have a single flare (I cannot remember though). So please don't cut the flare for my satisfaction, cut it so that we (me and the other internet users) can share the learning.
    A wise person once told me "show me someone who has never made a mistake, and I will show you someone who has never made anything."
    The original poster of the question notes that he has done some practise flares whereby the material does not appear to be "have as much meat", indicating that he may have a double flare.
    I like that saying LX90 is a diesel powered Cresta/Chaser/Mark2 thing, so the loss of the steer hose for one of those in the name of science (?) is no loss at all. At least it'll mean a definitive answer for all of us regarding what toyota do.
    I like your attitude, I also like to learn
    I think mrshin has come up with a good idea, which I was also thinking of doing. I thinking alsong the lines of getting some lines from another toyota that has the power steer pump on the drivers side, same as my 1g, and then modifying to suit. Ill see how I go.
    This discussion is getting intense, I like it!
    Tallahassee, FL USofA
    That pic sure looks like a double to me!
    There we go. Looking at it, the material is quite thick so I guess double flaring would be difficult to do on it? Maybe double flaring a thinner tube wall like a brake line is needed to prevent splitting when the nut is tightened onto it?
    Whale oil beef hooked (say that quickly with an Irish accent).
    I actually thought about this yesterday and I realissed that the material that Toyota is currently using (as pictured) is just too thick to double flare. I am not sure that they have always been done this way. [edit] yes there is an echo in here [/edit]
    Jase is wrong again ***sighs and resigns oneself back to work***.
  1. Power steering too light.. how to fix??
    Last Post: 07-12-2007, 12:20 AM
  2. accidently toped up power steering with brake fluid?
    By gerald1 in forum Tech and Conversions
    Last Post: 12-08-2006, 06:52 PM
  3. AE82 Manual ---> Power steering conversion ease
    By hemi twofifteen turbo in forum Tech and Conversions
    Last Post: 24-05-2006, 06:09 PM
  4. power steering fluid
    By off-road in forum Tech and Conversions
    Last Post: 12-03-2006, 09:48 PM
  5. Power Steering (n00b question)
    By ZZE92 in forum Tech and Conversions
    Last Post: 29-12-2005, 12:52 AM
