Fired it up with new turbo today, tested the amount of oil flow to turbo per minute and its twice the recomended rate, so will be adding a restrictor to feed line tommorrow.
That's pretty impressive.
dude that looks awesome!
what have you been welding with?
Tig or Mig?
Project Soarer II - Sold
Evo 5 - The silver fruitbox
Originally Posted by MR 1JZ
have only mig, waiting for my stuff to arrive from NZ, my tig is with that.
goddamn thats some neat welding for a mig!
mad props!
also have you got an alloy steering shaft spacer for the silvia?
definitiely invest in one...made such a difference on mine...
also...
you will wanna invest in:
Rear Toe Arms
Rear Camber Arms
Rear Traction Rods
all of that shit really stiffens up the rear of the car and gives you a crapload of adjustment
usually around $150-$175 for each pair of items
cant spend money better on nissans IMO
dude, thats awesome, bit more poke then an sr20 im guessing![]()
sorry if you have mentioned this before, but what is the car gonna be used for.. drift/daily driver/drag etc... or all of the above... i think there is a few silvias going round with 1j's, even a 1uz but i've never seen a 2j in one... good work mate +rep for joo!
Edit.. just read the track car only bit.. should be sweet, keep us posted..
Stomps
havn't got any of those things yet, have spent last of my coin on converting to s14 hubs and brakes and turbo, will have to drift it like it is, will just weld diff up first.Originally Posted by MR 1JZ
fair enough
you got coilovers and castor rods?
JIC in front and teins in rear, havn't any castor rods yet. Picked up custom sway bar yesturday.
Booked in for dyno tuesday, cant wait!
dyno today found a gremlin, have pulled off turbo. manifold and wastegate, after looking at wastegate pipe off manifold the hole that has been cut is only 32-35 mm diameter and isn't flowing enough gases to control boost.
When car was on dyno it held 10 psi until getting over 4000rpm, then boost climbed as rpm rose, the tunner run it up to 5500rpm and it was up to 17psi, after playing with boost controller and waste gate boost lines he stoped the tune.
I was using a 50mm hks copy waste gate but am concerned about this so have got a turbosmart 45mm progate coming which will fit with twin feeds off manifold.
It made 240 rwkw @5500rpm, 17 psi before he shut it down.
Standard motor with standard injectors, he did note the injectore wearnt at 100% duty cycle, which is a good thing.
Beware of ebay manifolds with this fault, mine come from monster performance, you do get what you pay for, in my case i paid $153 delivered so am happy to modify it!
That will fix the boost control issues!!
Am also changing exhaust housing from 1.06 to 0.82 to get the boost on earlier
hey dude, make sure you put some ultra blue on both Vbands...they leak like a siv sometimes
awesome! just register to post that! any updates on how the car is running?
runs completed on stock engine, injectors and feul reg.
black run 16 psi
red run 9psi
16psi run had injectors at 95% duty
I only plan on running 9psi to get a feel of car for start
Hmmm, the smooth 2J power...![]()
1986 RT-142 Corona. Taking the phrase “WTF”, to a whole new level......
PHOBIA. Fear of.........investing your soul into customizing a "f@#kin what" a Corona???
Click to see PHOBIA
