Results 1 to 15 of 16
Thread: mteu injector size?
    Junior Member Backyard Mechanic sam-131's Avatar
    Default mteu injector size?
    i was wondering what size are the metu's injectors? also are there any larger ones that bolt in ?
    thanks
    Sam
    Default Re: mteu injector size?
    182cc I think :S (not sure on that)
    I think XF falcon are close to a bolt in (serach on the old forums...), also not 100% on that!
    ed_ma61 (now ed_jza80) was involved in looking at it...
    Penrith BC
    anything can be made to bolt in... but why?
    what do you need the fuel for?
    ../delete/ban
    tech moderator
    i got a new daily mz10 and i just got a 5me off viper(james) so the plan is to use the manifolds off the mteu on the 5m to make a 5mteu i an i was thinking that the mteu injectors might shit them selfs so thus me wanting to now what would fit
    i heard that 22re injectors might fit any ideas?
    I doubt the stock 5me ones will struggle...
    Penrith BC
    dude - any injector can be made to fit
    run the 5me intake manifold and the 5me injectors and rail
    run the mteu exhaust manifold
    adjustable fuel pressure reg will get you a few extra bits of juice, or go to the xf injectors
    search the old site for more info
    ../delete/ban
    tech moderator
    what ecu would you run mteu's or the 5me's? i plan on on playing with the afm later on to tune i slightly
    Penrith BC
    just run the 5me ecu
    forget the afm fiddle
    just get a pwm unit from jaycar - much better way to play
    ../delete/ban
    tech moderator
    I'd prbly try and run the mteu one... the mteu one has an o2 sensor input...
    Penrith BC
    yeah, but itll be mapped for ?smaller injectors and on 2L versus the 5me inj and 2.8L
    ../delete/ban
    tech moderator
    hmmmm thats what i was thinking also thats why i said i would fiddle with the afm to richen it up a bit meh but if i run the 5me ecu i would need a 5me loom and re wire the sourarse
    Quote Originally Posted by ed_jza80
    I was under the impression that the injectors were the same...
    I suspect both could be made to work
    Penrith BC
    true that... it does only run fuel afterall...
    which brings me to: dont forget to swap the mteu dizzy over = boost retard
    ../delete/ban
    tech moderator
    note taken i've been reading up on the old forums about it but it dosnt say anything about the xf injectors are they a straight fit? go easy on me i am a newbie to efi
    Penrith BC
    http://forums.toymods.org.au/index.p..._view=&start=0
    http://forums.toymods.org.au/index.p...art=0&count=60
    its possible that other info is on the OLD old forums - i have no idea where that forum is anymore...
    ../delete/ban
    tech moderator
  1. 1GEU > MTEU + Auto > Manual in GA61 swap
    By KwS in forum Tech and Conversions
    Last Post: 06-12-2005, 01:36 PM
