Q1. 5mm should be alright, so long as its metal, if any is rubber it will need to be replaced with efi graded hose, most std efi metal lines that run under the car wouldnt be much, if any bigger.
Q2, mount it in the tank if you can, under the car if you can find somewhere where its out of the way and wont be hit by a speedbump etc, the boot would also be fine. personal choice on that one. in line under the car would be easiest if you cannot mount it in the tank as you dont have to run lines into the boot and back out again.
Q4. youll find the "suction" or feed line would enter the top of the tank and extend down into the bottom of the tank. use the standard feed line from tank. the return will drop off in the top of the tank somewhere so will not work as a feed.
Q5. id use a rubber mount weather its a problem or not, unless you want to sound like an aeroplane taking off all the time![]()
