Sounds fine.
That is how MS-6X (and possibly other model) Crown fuel systems are set-up.
ie, supply line, pump, carby, reg, return line.
Just make sure you have an oil pressure switch fitted up so the electric pump (if you use one) only runs when you have oil pressure, otherwise it will run all the time when the ignition is on which is dangerous in the case of an accident/roll-over.
Also, you only need a carby pump as the pressure only needs to be 6-10 psi or so, not an EFI pump, and you can scrounge the pressure reg off a Crown in a wreckers. You'll find it on the passengers side inner guard in the engine bay-you can't miss it.
Sean![]()
