Results 1 to 15 of 18
Thread: Boost controller on 1G twin turbo
    Aug 2006
    Default Boost controller on 1G twin turbo
    Hey guys, just got a GFB Atomic boost controller for my car, and am having trouble hooking it up. how i was told to run the hoses, makes no difference to the boost after adjusting the controller. i was told to run a hose from both turbos, put in a T piece, go to controller, then T piece with hose going to both waste gates (sorry guys hard to explain)
    something like this
    TURBO------T PIECE------TURBO
    | H
    | O
    | S
    | E
    BOOST CONTROLLER
    | H
    | O
    | S
    | E
    W/ GATE---T PIECE---W/ GATE
    any help would be greatly appreciated, as i dont know if i have been given bad information?
    thanks
    josh
    Default Re: Boost controller on 1G twin turbo
    some if not all of the toyota engines have valves for the ecu to know when to perform boost cut, meaning 2 hoses coming off both gates, the one going to the valve needs to be blocked for the controller to work (this may not be the case with the 1g).
    does the 1g run parralell or sequential? if sequential you may have connected it to the "prespool actuator"
    i'm pretty sure the 1g has no such boost cut in the ecu, only a maximum amount the afm can read.
    what you have done sounds right. have you adjusted it correctly? maybe you hooked the valve up backwards?
    Hello.
    Aug 2006
    i put the controller in for the flow to go from turbo to waste gate as per the instructions. after turning about 16 turns out and no change, i tried hooking the controller up for the flow to run the opposite way, but still no change? maybe i hooked the hoses up wrong?
    Junior Member Backyard Mechanic SIKTOY's Avatar
    When iI set mine up I put a T peice on each turbo between w/gate and turbo and ran a hose of each to another T peice to the boost controller.
    For you boost controller to work it must vent into the air
    I would draw a diagram but my pen didnt work on the computer screen
    Ben
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    Aug 2006
    aaaah i know what you mean, will give it a try like that.
    thanks heaps for the help all.
    if you could get a photo of the controller it may help. maybe google images the model and post a pic?
    Hello.
    I am not familiar with the actual boost controller but if your boost controller has a pressure in and a pressure out, then the normal set up is to just remove the hose from each turbo to it's actuator. Bung up the hole on the turbos (I use a bit of tube with a bolt stuck in it). Put a T piece between the two wastgates and hook this to your controller. The pressure feed for the controller (the other line) is better if it comes from your inlet manifold and there is plenty of nipples there to choose from.
    If it only has a pressure in and no pressure out then setup as Ben (Siktoy) suggested.
    if it comes from the inlet manifold the reading isnt as accurate though.
    West Australia
    | H
    | O
    | S
    | E
    BOOST CONTROLLER
    | H
    | O
    | S
    | E
    That is correct
    What you have is the correct setup.
    Try, just for fun, remove the boost controller from your setup, and just block off (bolt or something, the two open ends your left with.
    EG
    | H
    | O
    | S
    | E
    BOLT
    BOLT
    | H
    | O
    | S
    | E
    What that will do is allow you to run unlimited boost.. Try running the car like that, (be VERY VERY gentle, because you'll get silly boost real quick!) and see if you hit some sort of boost cut. If you don't, and you get silly boost, then you must have a dodgy boost controller.
    Facebook | LinkedIn
    just a note on what strad said, if you have a stock engine / ecu / afm it should cut out around 15-17psi.
    Hello.
    So there is a boost cut?
    Facebook | LinkedIn
    West Australia
    1G boost cut i dont think exists , as i got to ~18PSI accidently once,
    Around that point the car went mental , because i think ECU fuel cut is at ~16psi
    Quote Originally Posted by willwal98
    That seems dependent on the ECU, my car would do it at 14.5psi with the Gen2 ECU and around 15.5psi on the Gen3.
  1. twincharging prototypes needing constructive critisism (SC14 + turbo)
    Last Post: 11-10-2014, 01:02 AM
  2. closing a boost controller......what would the effect be?
    Last Post: 08-09-2006, 05:44 PM
  3. Boost Leak Tester
    Last Post: 01-06-2006, 12:25 PM
  4. GFB Boost Controller > MA70
    By EldarO in forum Tech and Conversions
    Last Post: 16-04-2006, 05:39 PM
  5. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 04:53 PM
