Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 105
Thread: 18RGEU Wiring Woes (56K BWARE) *It was alive NOW DEAD*
  1. #61
    Default Re: 18RGEU Wiring Woes (56K BWARE)
    Quote Originally Posted by Spectre
    Ok alot of talk but no one seems to be able to answer my question about the AFM pins.
    Is the order on the Wiring diagram correct in coresponding to the pinouts on the AFM. So is this right:
    ** pic was here**
    ? I have 4 wires that im fairly sure about, but I have three that went nowhere on both looms that I had.
    Cheers, Bryce
    No no no...
    AFM WIRING
    looking at the connector on the AFM itself, from left to right you have:
    E1-Fc-E2-Vb-Vc-Vs-THA
    E1 - earth for Fc
    Fc - fuel control switch, turns on circuit opening relay (fuel pump relay)
    E2 - earth for AFM
    Vb - to Vb pin on ecu
    Vc - to Vc on ecu
    Vs - to Vs on ecu
    THA - air temp sensor, to THA on ecu.
    ...... butt scratcher?!
  2. #62
    ok so is this right? or have i got it back to front?
  3. #63
    well depends if that is the right way up for how the plug is plugged into the AFM.
    If it is, then you have it correct
  4. #64
    Ok, have been laying out all the wires to get the right lengths in the bay before i start soldering. Have one or two more questions.
    This is a earth correct?
    The dark blue plug in between the injectors is?
    where abouts do I plug into the starter?
  5. #65
    New Zealand
    Dark blue plug looks like cold start injector, start will have a small spade terminal on the solenoid at the top.
  6. #66
    1. Not sure which wire you're referring to?
    2. Blue plug is the idle up valve.
    3. As mentioned there is a spade terminal on the starter solenoid.
  7. #67
    In the first picture, its the black plug in the middle of the shot.
    The idle up, where does that connect to? as I cant find it in the wiring diagram.
  8. #68
    New Zealand
    Aha, that would be the cold start. You can see the fuel line running into it.
    Callum
  9. #69
    I'm pretty sure it just needs +12v when the ignition is on.
  10. #70
    As has been mentioned mate, the black plug is the cold start injector plug.
    The blue plug is the auxiliiary air valve (it introduces extra air when the engine is cold) it just needs a +12V when the engine is running...so it can be run off the switched main relay line. I'll have to update the wiring diagram with this as well...
    Here is an excerpt from the AutoShop 101 Toyota PDF's
    As others have said there is a spade terminal on the starter motor, I've attached a picture to assist you mate.
  11. #71
    Spectre, if you are still having dramas, please see this thread:
    http://www.toymods.net/forums/showth...282#post252282
    My loom and ecu and AFM are now up for grabs.
  12. #72
    PMed Witzl.
  13. #73
    too late sorry - you were beaten to it.
  14. #74
    Bugger. Still chasing a full complete diagram...
  15. #75
    Mad Man Grease Monkey 77GZE's Avatar
    Hey mate, ha, looks like a mess, just get a time to come round and ill pin mine out with you, just finished mine, u know where to find me
    Steve
  1. Needed! - RA63 Wiring Diagram
    By Spectre in forum Tech and Conversions
    Last Post: 06-09-2006, 11:54 AM
  2. Wiring Experts! Seperating looms for engine swaps?
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 29-08-2006, 07:29 PM
  3. understanding 4agze wiring diagram-HELP-
    By slide86 in forum Tech and Conversions
    Last Post: 18-04-2006, 07:09 PM
