Ok almost done! All wires to the ECU have been wired, relays done. Only a few things im not sure about:
VB Wire: theres a pinout on the ecu for "VB" but the diagrams show it intersecting the line from the +coil. Which is right?
Do the fuse holders/fuses have to go a certain way? or are they the same both ways?
My ballast resistor has had two wires cut off. do these matter? It came off what i was told was a running loom / engine.
The 12V for the Ballast resistor - is this it? Its the only wire not coming out of the large plug.
Idle-Up Valve - 12V constant? Where do I join it to?
Which of these two points do I attach the -IG to? Is there a marking on the coil to say which is positive and which is negative?
Also, where can I take Ignition from? Which wires, and where can I find them exactly?
Bryce
