Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Thread: Using longer pushrod for clutch slave cylinder...A Bad Idea?
    cease striving Conversion King RobST162's Avatar
    Default Re: Using longer pushrod for clutch slave cylinder...A Bad Idea?
    UMMMM Dude did you read that I want a clean solution, so if Nick got an aftermarket one somewhere local would I not be interested?
    I have already been in communication with Nate at speed source to get one sent.
    I think that translates to advice taken.
    Quote Originally Posted by RobST162
    ^^^ eek cuts I don't want to take the motor out no matter what at this stage.. lol anything to avoid that!
    dale, yeah might try and get a rod made up.. good to hear bout your bearing being fine
    so you don't (dale) have any freeplay then in the pedal I guess...??\
    edit: would a longer slave cylinder rod pull the dust-cover off when extended??
    The grabbing point is still pretty close to the floor, but it's better than it was... it doesn't pull the dust cover off, you just slide it down the rod a bit more
    There's nothing messy about doing it my way, you'd never know it was any different to normal as the dust cover sits over 80% of it anyway... takes 5 minutes with an angle grinder and about $2
    Why get offended toda? While buying one from that site would work... why would you spend $20+ on something that is simply a small piece of steel that you can make yourself for a couple of dollars?
    I am the sun
