Shouldnt be any problem. Infact if you go to a brake place and ask nicely you can probably get an adjustable pushrod for your slave. I will be running a longer rod on my race car as i occasionally pop the piston out when i get fired up.
If you think abotu the hydraulic system then the distance that the piston is resting in the bore doesnt matter overly, it is merely the range of movement it has. Also most pistons will have a rest so they cant slip down too far into the bore and block off the feed.
