Aaaah okay, so you're running the Caldina engine, with grey intake manifold and rocker cover?
And presumably the auto ECU too?
my spare beams engine has the auto ECU to suit an ST202, I'm not sure how easy it is to get running with a manual transmission?
Also according to the stats, one beams engine makes 152 ft lbs @ 6000rpm and 200hp at 7000rpm, and the other (presumably auto version) makes 152 ft lbs @ 6000rpm and 190hp @ 7000rpm.
surely if peak torque and HP are at the same points, and max torque is the exact same figure, surely this must indicate that one version (presumably the auto, or maybe engine for the 4WD Caldina?) is detuned at higher RPMs, rather than physically different?
Glenn AKA Celica RA45 says all of the engines are the same, but I wonder if the ECUs are what makes the difference.
