theres few things u need to wire up to get cruise to work
bring car to me and ill get it to work easily
Hi All,
My Cruise Control doesn't work!
The auto Elec tells me the system isn't getting pulses from the transmission and or tacho or speedo.
Anyone that has done the 1UZ conversion and kept the cruise control?
How do I fix it??
Any help would be great.
Dennis
The cruise control system is a standalone system completely separate from the engine ecu.
If you have the cruise physically hooked up, and the speedo works, then the cruise will work.
If the speedo doesn't work, the cruise will not work.
Originally Posted by CrUZida
Speedo works, Tacho works, Push on switch for cruise on the column stork and my cruise light comes on, on the dash, but when trying to set, nothing happens.
This is my dilemma.
Cheers, D
PM sent, thanksOriginally Posted by sideshow
aSame problem with my Cruise control also..
Mos is going to have a look at it for me, but the bloke is just too damn busyAnyone have a cloning machine, I reckon the world needs a few more Mos's , or is that Mosi ??
The only thing I can think of is that the cruise ecu needs to know that the gbox is in "D" for it to work.
Make sure that pin is correct.
Once "D" is engaged, and its getting a speed signal, it should work
There is a sensor mounted on side of transmission very nearly next to the speedo cable with a 3 pin triangular plug on the end of about 100mm of wire.
I'm guessing this is the speed sensor, but it has a different plug to the MX83 loom.
Is the MX83 version interchangeable with the soarer.
Thanks, D
that is the abs sensor
the cruise needs signals from the orig ecu to work but they can be tricked
and if u have fitted a manual gbox its abit more things to do
OD1 and OD 2 must be hooked up to the efi ecu but u can trick the signals
D
it takes 20 mins to fix
but i guess no one wants to pay to get it fixed
im over all this helping shit
cant be fukt anymore
sideshow, if you can fix this, i will show the money, its giving me the S**ts sitting on the highway... and having currently pointless lever on my steering wheel
2JZ-GTE MX-83 Cressida
Toymods Car Club Club Member # 185
I'll pay, for sh!t's sake I have had Auto Elecs look at it and run away.Originally Posted by sideshow
Tell me where you are and I'll be there and I'll PAY
Dennis
My original MX83 has a speed sensor in the same place, but as it's a GXL it doesn't have ABS, so what do I do now?Originally Posted by sideshow
I'll come to you with some dollars but can't go to just nowhere. I would like it fixed before I go to Melbourne on the 6th October if you can fit it in.
Dennis
Sideshow,
You remember this!
But no mention of any money and it was on 12th September 2006.
It's now 29th September 2006 and no more than words from you.
The going rate for an auto elec is $70/hour, I'll pay you $100 if you can fix it and by your own determination, that equates to $300/hour, but as I said I would like it fixed before I go to Melbourne in now less than a week.
Can you do this, or not?
Dennis
