Results 1 to 5 of 5
Thread: Supercharger clutch timer
    Default Supercharger clutch timer
    Hey dude,
    I was wanting to setup a clutch on a supercharger to engage and dis-engage on load, however I dont want this happening everytime I change gear, so I was wondering how to delay the disengaging, is there some kind of device that I can use that will allow an ajustable time between loosing signal(load signal from ECU) and toggling the clutch to disengage?
    Thanks in advance for any help given.
    Jun 2006
    Default Re: Supercharger clutch timer
    Hi
    Something like this
    http://www.oceancontrols.com.au/coun...timer_k141.htm
    http://www.oceancontrols.com.au/coun...imodetimer.pdf
    Use the power from circuit that you are going to engage supercharger clutch though a brake light type switch on clutch pedal to trigger start circuit, set to instant on, delayed off edge triggered.
    That way when supercharger is on and touch clutch pedal switches power into supercharger clutch for what ever time it is set at.
    regards
    jon
    User Conversion King
    NWA
    maybe you could wire the SC clutch such that it can be put in 3 modes.
    one is permanently off, one is permanantly on and the other is 'auto' ie controlled by the ECU.
    all you need is a 3 pin, 3 position toggle switch that you can buy from jaycar etc.
    the middle pin will be the output that goes to the SC, one of the outers will have a constant 12v supply, and the other outer pin has the SC on/off feed from the ECU
    Quote Originally Posted by WindeX
    Hey dude,
    and who exactly are you talking to
    hello
    Victoria, Mt Macedon
    You can run a little circuit between your ECU (I assume aftermarket of some description) and the SC clutch. The circuit will switch the clutch on as soon as the ECU commands, but wait for a period before switching it off if the ECU signal drops.
    It's described here
    Note that the ECU output must pull to earth when active and go to open circuit (or 12V) when not active for the circuit to work.
    Simple to wire up.
    Hen
    PS, Chookhouse Chooning FTW
    I used a Jaycar timer kit, but Hen's solution is more elegant.
  1. Clutch fork problem
    By Spode in forum Tech and Conversions
    Last Post: 21-08-2006, 10:30 PM
  2. AE86 Clutch Help
    By Trizae in forum Tech and Conversions
    Last Post: 20-04-2006, 11:08 PM
  3. Grease on flywheel / rear clutch surface..wtf!
    Last Post: 27-03-2006, 12:14 PM
  4. W58 7M-GTE clutch choice
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 03-02-2006, 07:57 PM
