Results 1 to 8 of 8
Thread: 1jzgte TPS check
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Default 1jzgte TPS check
    Anyone know how to check if the TPS is workin properly on a 1jzgte. Does somone know the resistance value's.
    1994 GZX90 Mark II 1GZ-FE V12
    Junior Member Backyard Mechanic 82MKII's Avatar
    Default Re: 1jzgte TPS check
    Triptek,
    have a look at http://mkiv.supras.org.nz/articles/engine_2_41.htm
    Unfortunately it is for the 2J, but there is a pretty good chance the resistance values (for the TPS and not the sub-TPS) are the same. Is anyone able to confirm the resistance values are the same?
    Regards
    Peter
    I set my 1jz up using the 2jzgte values once...made it stall when i came to a stop...
    I can't remember if I reset the ECU tho...
    Thanks guys it's all fixed.
    Junior Member Domestic Engineer urantia's Avatar
    triptek, can you elborate, did you use the 2jz tps settings to fix it?
    after what wilbo said i'd like to know for sure if the 2jz tps settings are ok to use on the 1jz tps.
    98 3rz-fe Hilux 4x4
    97 Hiace AWD Super Custom 1kz turbo diesel (sold)
    87 MA70 w/ 1JZ-GTE Manual Conversion GT (moss growing on roof deteriorating away but open to offers)
    Wasn't the tps mate. It was a huge vac leak through the injector ports on the manifold.
    Also i did compare the 1jz tps specs to my 2jzgte one and they were the same.
    np, glad you got it sorted.
    (still if anyone knows for sure about using 2jz tps settings on 1jz would be appreciated and pos repped)
    (you snuck a post in there before i posted this)
    well then sounds like you've answered my question plus rep for you)
    98 3rz-fe Hilux 4x4
  1. tps calibration
    Last Post: 10-07-2006, 11:38 AM
  2. TPS Problem
    Last Post: 28-04-2006, 02:10 PM
  3. TPS Idle Switch
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 19-03-2006, 05:44 PM
  4. Full-variable output TPS - what cars ??
    Last Post: 20-02-2006, 11:59 AM
