Results 1 to 15 of 22
Thread: How are by-wire throttles controlled??
    Victoria, Mt Macedon
    Default How are by-wire throttles controlled??
    While daydreaming about some long term projects, I got to thinking about by-wire or electronically controlled throttles. I understand their function and advantages, but what I don't know is how they are controlled (I've never pulled one apart either).
    Has anyone played with them? Do they use a stepper motor? PWM? Servo control? How many control wires do they use? Would it be convceivable to build a home made controller for one of them?
    And does anyone have suggestions for a good, easily available and cheap by-wire throttle?
    I tried a while on Google, and found a few mentions of PWM and servo controlled throttles, however further info is always good.
    Hen
    Default Re: How are by-wire throttles controlled??
    swap me something to bolt on to the 2j in place of my by wire system and you can have it
    Quote Originally Posted by Draven
    and the computer to run it
    I have a throtle pedal setup here for one! There are not cheap either around the $1000 mark for a bloody potentiometer on a pedal assembly.
    This ones off the latest Kenworth 604 semi, hahahaha making a Tig foot switch out of it!
    Its a great idea but i would be waiting till it becomes more common place and the aftermarket computers start running them.
    I only say this from a cost point of view and saftey poin of view.
    Montrose
    Motec has been able to control one for several years now.. Grab a pedal and throttle from a suitable donor car, and let the fun begin.
    Yep and it will be a very cheap setup! hahahahahahahahahahahah
    Suppose i should add, you would be mad to even use it in a lemans car, as you have electrical parts to go wrong were in the best setup the cable can only snap and take two seconds to fix
    Montrose
    Well, I can MAKE it cheep:
    Ok ill have 500 cheap motecs thanks!hahahahahah
    south australia
    well basically there is a pedal position sensor thats in the cabin. that basically tells the ecu what positin the throttle is at. ie 15% down. this then gets transfered to the throttle body which has a small motor to control the throttle butterfly.
    the system is ok, but its a bit delayed. you put your foot down and then a few seconds later after the ECU has all the calculations done, then it opens the throttle. it can get a bit annoying
    "pedal position sensor" is a potentiometer, same as a TPS.
    Quote Originally Posted by slide86
    Mate crap, you have never driven one have you? or know anything about it?
    If the 540 BMW i have sitting at home did the claimed 5.2 or 0-100 that would mean they could take a secound of that time using a cable and save themselves a tens of millions of dollars!
    Stop learning of web sites or bad ones!lol
    p.s a few seconds would make the 540 do the 0-100 in 2.2 seconds with a cable! i want one of those 540's!
    I have to side with mick here... my jza80 (vvti - drive by wire) has at least as good response as my throttle cable 1j. I don't really notice it's there to be honest.
    what no-one's actually addressed is what kind of drive mechanism?
    e.g. is it a stepper motor (like a 1G aux-air-valve) that requires electromotive force to open AND close it (highly unlikely) or is a PWM-driven solenoid (like an XF idle-air valve) that rotates or pushes a lever and relies on a spring to return the a home position (more likely as electrical failure causes closed throttle).
    Reason i think it's the latter is that drive-by-wire throttles (that i've seen anyway) have a TPS on the opposite side of the driving unit - so the the driving unit doesn't do any positioning - ergo it's a PWM-driven solenoid.
    cheers,
    charles.
    I'm not going out to check now, but from what I can remember you're right chuck - TPS on opposite side to drive unit
    Same here, if we dont use it racing i aint checking it now in the cold!hahahaha
    but if someone really wants to know ill take picks of the BMW setup in the next few days when i get a chance!
    i'll have a look at the BA or VE setup at work when i get the chance, i have a few ideas how they work and should work, but wont post up opinions just yet.
    i was all for the idea until i put on a working throttle body.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
  1. HELP - how to wire up a fuel pump
    Last Post: 21-06-2007, 12:15 PM
  2. finding my headlamp wire
    By AE101LEV in forum Tech and Conversions
    Last Post: 21-05-2006, 09:36 AM
  3. magnetic pickup in dizzy, which wire is + which is -
    Last Post: 11-05-2006, 12:13 PM
  4. URGENT!RA60 fusable crossover wire magiver quick fix?
    By andyroo in forum Tech and Conversions
    Last Post: 03-01-2006, 08:11 PM
