Results 1 to 9 of 9
Thread: 2tg electronic ignition...
    Default 2tg electronic ignition...
    Hey guys,
    Trying to work out how to set up the electronic ignition to a 2tg running twin carbs. There is a 2 wire plug from the dissy. This connects to either side of the coil. Then there are 3 wires coming off the igniter. A black with white stripe wire, a blue wire and a red wire. The black with white splits into 2 more. Any thoughts...
    Hoppers Crossing
    Default Re: 2tg electronic ignition...
    SD
    i didn't run an ignitor on mine
    the black wire from the dizzy went to the - on the coil. the black/red wire went to positive coil...
    I was under the impression the igniter was required to boost the signal....? I know people have run them before though...
    FRustrated INdividuaL !! Grease Monkey Rosey's Avatar
    Iam in the same boat as your shelldrake, but I have not got the ignitor yet but when I do I'll need the wiring diagram as well.
    Rosey
    check the wiring diagram for a 21R/22R
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    Quote Originally Posted by shelldrake
    Some of the 2TG elec dizzys have the ignitor inside the dizzy, some are external... have a look inside
    Time to spank the Grease Monkey
    The early 2TGEUs had an external igniter, later ones had internal. If its Internal you should have two wires coming out of it, can't remember colours, but on the black plastic inside the dizzy covering the igniter (and theres another one covering the pick-up) it indicates which wire should go where, by a B or C or something (I didn't know my first dizzy was internal and broke it so had to get an externally regulated one from NZ - bummer...).
    AE92 Lueno GT-Apex (zenki Trueno with a Levin front end) - BT 20V & LSD
    KE30 Tudor - 2T-GEU, T50, T292
    Hoppers Crossing
    yeah. look inside the dizzy
    if its got two "kidneys" or black things innit, then its got an internal ignitor.
    if only one, then it requires an external ignitior
    as my 2T is in pieces i'll grab a pic tonite
    awesome. I'll suss it out. Cheers Guys.
  1. 2TG Electronic Dizzy
    By Grega in forum Tech and Conversions
    Last Post: 26-07-2006, 08:41 AM
  2. 18RG electronic ignition
    By ROHANVII in forum Tech and Conversions
    Last Post: 23-07-2006, 08:56 AM
