Results 1 to 7 of 7
Thread: Mega Squirt II boosted VE table?
    Perth, WA
    Default Mega Squirt II boosted VE table?
    any one can share the VE table for their Mega Squirt II on their boosted engine? i'm using MS II on V3 board and use it for my 3TC Turbo controlling the fuel only...
    cheers...
    Default Re: Mega Squirt II boosted VE table?
    www.msefi.com..........
    Perth, WA
    any one with the VE table?
    cbh: mine is still in alpha mode - i also have a rising rate fuel regulator so my VE table looks a bit anemic in the boosted zone
    I'd suggest looking for folks on msefi with turbo 8v engine.
    PM me an email address and i can post you what i've found (mitsu turbo, golf turbo with edis) plus my own table.
    These are from a single turbo 1jz-gte.
    (BTW charles, this is the one I was referring to in that email)
    QUICKEST 1JZ'S IN OZ
    hi chris,
    impressive looking table - especially the high VE numbers when at high boost plus high rpm.
    'cause i was stupid enough to get a rising rate regulator, i wont be adding that much in boosted territory.
    Am surprised that the map for timing only has a small area for idle... i will go home and ponder this further. Plus - as suggested in my thread on timing - i'm lifting the timing in the lowest rpm bin so if the motor starts to stall it bumps it back up with more advance.
    Perth, WA
    i've just generate one out from the "Online VE Generator". after i load it into my MS II, the engine response much more better that the previous VE table i have. it does not sluggish during acceleration and the RPM ramp up about 4000RPM and no sign of miss fire...
    haven't drive my car on the road yet.. just to play safe, how would you all think about this VE? i hope it it won't cause my engine have any melted pistons inside specially under boosted region...
  1. Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
    Last Post: 19-01-2015, 06:18 PM
  2. 3tgteu on Mega squirt?
    By 3jcelica in forum Tech and Conversions
    Last Post: 10-03-2008, 12:23 AM
  3. Mega Squirt 1G-GTE
    Last Post: 19-04-2006, 08:31 PM
