If you can't be arsed buying a special tool for removing a small bolt you broke the headoff it cos you're lazy like me, get a small drill bit and drill a hole in the centre of it, then drive a flat-blade screwdriver a smidge larger in width than the diameter of the hole. Use a hammer to get it in if it's resisting too much. If it has trouble budging, use a ring spanner on the screwdriver handle for leverage.
Worked fine for a seatbelt bolt the previous owner had broken and a couple of sump bolts that...I...kinda broke![]()
I tend not to use the washing powder nark, as my hands always have cuts one them cause of the amount i play with cars
