Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: Dual Circuit Masters
    Default Re: Dual Circuit Masters
    Well the measurements are as follows.
    the master cylinder has to be 140mm or shorter, bolt pattern 60mm vert, 17mm or greater bore. Its hard to find such a short one. Thats the only problem. Cant seem to find a length on the Rover '88 model one.
    I knew $303 is expensive, but it did take him almost a full day to find one he said. I went back over to his workshop and had a chat, Said he could do it for a bit cheaper than quoted. Well a fair bit cheaper so i gave him the go ahead. I had wanted to do it myself but i'm not too sure if i could get it done for cheaper, and it would also take me a while sourcing the parts.
    I have a driving day booked on 29th of this month so it needs to be on the road before then!
    I dont like my chances but least it might have a chance of getting there!
    KE20 - Soon 2 b gte!
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    hey i know its an old thread but the older squarer mazda 323 and meteor from late 70's, early 80's has a boosted dual circuit master cylinder with:
    60mm 2 bolt vertical flange
    short in length at around 120mm?
    wide reservoir at around 50mm?
    20.64 bore
    chrome is good Backyard Mechanic RO11LR's Avatar
    Hey Bretto , if your stil looking i have a master out of a 82 ford meteor 9 (prob same as laser/323 of same vintage ) it's a 11/16 , has same 60mm 2 bolt vertical flange and so far , from the limited driveway brake applications i've done seems to fill up my r32 skyline calipers , worth a look at , they have them at A.T.A.P . brand new for under a hundred bucks
    Lindzz
    Jun 2006
    hey and theres the man that discovered this dual circuit bolt in!
    i actually ended up going a gc galant at 3/4 inch (19.05mm) for my ke25
    with the ke55/ke70 brakes.
    its very slim and has seperate reservoir tanks for each circuit.
    all early galant masters are:
    dual circuit
    60mm 2 bolt flange
    slim and long
    connections up top
    there are 17.46mm, 19.05mm and 20.64mm bores avaliable
  1. Dual circut master cylinder help needed.
    By Bretto in forum Tech and Conversions
    Last Post: 10-07-2006, 02:18 PM
  2. 2006 AE86 Circuit Battle Extravaganza
    By AE86slut in forum Previous NSW Events
    Last Post: 30-05-2006, 05:29 PM
