Results 1 to 15 of 26
Thread: having problems winding boost over 15psi
    Default having problems winding boost over 15psi
    i have a turboXS tee piece in my car, i only have to wind the thingo 2 turns to get it from 11-14 psi, but have to turn it another 2 turns to get it to 15psi. i am worried that i might be spinning the turbos too hard and the bov may be leaking or is this just normal
    The boobs are back
    Default Re: having problems winding boost over 15psi
    no ithink i have the same piece, we have found that when u get around that PSI that the turns on the controller become very unpredicable, ie say half a turn one time was 2 psi and next time it jumped it 5 psi ! and was 20 psi ! the turbos will be fine im pretty sure. its just they are funny lil controllers.
    What is autosalon? Sounds kinda homo.
    Quote Originally Posted by tooch
    It's extremely homo. Basically a whole lot of sh1t cars, with ugly wheels, and a lot of 16-20 year old rockstars with trendy mullets and gay shirts.
    Slayer Of Toymods Wookie Slayers
    User Conversion King
    NWA
    it may mean your turbos are begininng to be used out of their efficiency range.
    or, your boost controller doesnt hold a linear relationship with the boost increase. ie one turn doesnt always equal 1 extra pound.
    dont 1jz's have ceramic turbos??? =smash?
    hello
    Viagra Enlarged Member Grease Monkey TRAV-KE55's Avatar
    Might mean that turbo's just dont have enough huff in em, or that you have a restriction (normally the factory intercoolers etc) and you boost gauge is reading from the inlet manafold side of the intercooler, so it wont give you a accurate measurement what you are actually acheiving with your boost controler.
    Then again maybe not!!!! hehe
    Trav
    Active Corolla abuser!!!
    Travis Robson
    0418 552 413
    I'm going with the bleed valve not being linear. I've found that with mine. (albeit a gas reg, not a bleed valve).
    Facebook | LinkedIn
    hey i have the same issue with my Turbosmart bleed valve
    sometimes you turn it heaps and it does f**k all and sometimes it raises boost by 3 or 4 psi.. its a random little bastard.. ..
    atm.. im running over 15psi on a factory ct-26..sometimes i can hear it reach full boost and a leaky air noise starts to occur.. its not the bov coz i checked.. any hints?
    yeh a stock ct26 will run out of efficiency at 15-16 psi, how olds the turbo ?
    solution - dont use mechanical bleed valves.
    Amen brother.
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    I found that a bleed valve if affected by outside temp - makes the boost pressure vary too much for my liking!
    Quote Originally Posted by Hydra
    Very true, the smaller the restrictor before the bleed the greater the variance.
    So what EBCs have people had success with? Have people found they "respond" quickly enough on cars with uber responsive turbos? i.e. smaller ones that spool extremely rapidly.
    My KE25 thread
    are the internal passages of the Tee piece become the biggest restriction?
    tried a bigger T piece (ie, internal bore same as the tube?)
    since you are bleeding air off, it needs to have flow, as opposed to a sense line (usual) which just needs pressure...
    Oh and another issue with new bleeders fresh out of the packet is that some brands like to grease up the needle in the bleeder and it's threads. I was getting some crazy adjustment values on a bleeder the other night that was brand new and after a quick dismantle and inspection there was wads of grease restricting the job of the bleed needle - grease removed and it worked fine.
    My KE25 thread
    I had an average result with my Gizzmo, but I've seen other people have no worries whatsoever. I had problems with boost yoyoing around my set point. My boost comes on fairly progressively to about 10psi then shoots up like a rocket to 17psi, you can see it on my dyno charts as a massive power jump and it feels like someones put a rocket under it.
    I ended up purchasing an eBoost2 and even with minimal tuning i've got it a heap better. When i have my Adaptronic and can do some logging i'm going to spend some time tweaking it to the nth degree and turn on the correction feature so I can force the controller to hold full boost to redline.
    Quote Originally Posted by JustCallMeFrank
    You haven't been able to hold the preset boost to redline with any other controllers? i.e. you have a falling boost curve?
    Glad I didn't get a Gizzmo then, I was going to pick one up in NZ (I thought the country of manufacture would be cheaper than here) but they were more expensive in the store there than here.
    My KE25 thread
  1. tt soarer over boosting
    By kremsra28 in forum Tech and Conversions
    Last Post: 07-06-2006, 09:34 PM
  2. Boost Leak Tester
  3. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
  4. Replies: 22
    Last Post: 15-03-2006, 01:24 AM
  5. TA63 boost spike problem
    By Diz44zy in forum Tech and Conversions
    Last Post: 28-01-2006, 11:44 AM
