Results 16 to 26 of 26
Thread: having problems winding boost over 15psi
    Default Re: having problems winding boost over 15psi
    The Gizzmo was more aggressive in how it held boost based on how high the gain setting was. Turbosmart took a different approach though, they realised that there is only so much you can do with that way so they provide a correction feature to explicitly control the drop-off.
    Increasing the sensitivity on the eBoost2 will also make the controller work a little harder to stop boost tailing off. I haven't played with this fully though, because without logging, it's hard to see what little stutters etc. are being made by me playing with the eBoost2, or the ECU
    its my mates old controller, he said dont bother playing with the gating part of it, the boost just spikes masively, so i tried it, and it DOES spike massively
    The boobs are back
    User Conversion King
    NWA
    try the turbotech boost controllers.... they use a ball bearing and spring to control the boost. they are on ebay often for about $30.
    its what i have...i find it hardly spikes at all on 15psi
    hello
    How many psi is the spike? Does it spike if you bring it on boost under load from say 1500rpm? What does it spike like if you bring it from vaccuum to boost (WOT) at over 4500rpm (usually the worst scenario for spiking)??
    I have always been interested in trying that style of boost control but I fear that on my car the spike would be too great to live with.
    There are a few of those turbo tech controllers on ebay now for $35 I think. They seem to get good reviews by people but I havent seen any feedback from anyone running around 20psi yet with one - most are just running a little over stock boost.
    My KE25 thread
    Offset is king Grease Monkey monkeymajik's Avatar
    I have a turbotech one. great for the money but...
    Mine spikes 1-2psi at a 13psi setting
    monkeymajik
    "Recommended for those who prefer
    hot driving action and big angle drift."
    JDM Style Tuning - Super Late Braking Technique!
    Quote Originally Posted by monkeymajik
    Interesting. What length approximately would the line be from your boost reference point to the controller to the wategate?
    My KE25 thread
    My boost gauge is plumbed in at the manifold (though it is on the same line as the BOV which some say is not always a good idea).
    The length of vac line from actuator to boost controller to compressor is <15cm
    monkeymajik
    That's quite good it shouldn't be contributing to spiking much at all.
    The boost gauge/BOV on the same line won't cause too much trouble, you probably wouldn't notice the slight fluctuations that may occur in the readings anyway.
    My KE25 thread
    NWA
    about 0.5psi for this scenario
    about 1psi for this scenario
    im only running ~14psi (max) at the moment but it seems to only spike about 0.5-1psi.
    i am running reasonably long hoses to each wastegate too. the siamese turbos means the watstegate actuators at at each end of the motor
    hello
    What do people think about the greddy profec-B specII?
    monkeymajik
    Toymods Tuner Backyard Mechanic Forcefed6's Avatar
    I am using a Profec B Spec 2, and find it great... but it does take abit to get it to work right. The original Profec B and the current Profec B Spec S are a much simpler unit to operate and more user friendly..
    All of the above when setup correctly, will hold boost to redline.
    Z10 Soarer - [email protected] ... 11's soon
    CHECK IT OUT HERE
  1. tt soarer over boosting
    By kremsra28 in forum Tech and Conversions
    Last Post: 07-06-2006, 09:34 PM
  2. Boost Leak Tester
  3. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
  4. Replies: 22
    Last Post: 15-03-2006, 01:24 AM
  5. TA63 boost spike problem
    By Diz44zy in forum Tech and Conversions
    Last Post: 28-01-2006, 11:44 AM
