Results 1 to 9 of 9
Thread: inverted 3 piece wheels...
    May 2006
    california
    Question inverted 3 piece wheels...
    looking into buying some dori x2 15x6.5 +30 wheels. they are pretty cheap but the owner has reversed the face to make them a negative offset.
    I've searched all over and can't find any info. Wondering if there are ill side effects to this process???
    thanks chaps..
    jeremy
    Default Re: inverted 3 piece wheels...
    what?
    you mean the outer face of the rim centre is now mounting to your hub?
    Yes, I would say that is A Very Bad Thing
    Gorilla Industries Conversion King Koffee-Black's Avatar
    lol hahaha, buy them, so I can see it hahaa
    JZA80 Turbo Time Attack Car - "Gorilla"
    JZA80 Turbo Street Car - "Silver Back"
    Lexus RX350 F Sport "Kid Hauler"
    Vitz - Supercharged "Chimp"
    HDJ80 Landcruiser "Baboon"
    Perth WA
    If he's simply changed the hoops around, no problems, especially if both hoops have a faced finish (not many do, so anyone else contemplating this swap would also be up for finishing to make the mags look respectable. I assume your wheel bearings are suitable for the different load, but given some of the wheel sizes and offsets people try to run these days ...
    I'd assume his wheel bearings are NOT suitable for the different load
    and yeah, if the hoops are swapped it will probably look ugly but be ok. fyi: neither of my 3-piece rims (Work and Simmons) have a proper finish on the inner hoops
    As long as all the bolts were done up in the right pattern to the right torque settings and the factory balance wasn't upset...
    RM.
    May 2006
    california
    thanks for all the replies! i'm assuming he's an 86 noob given his join date on the forum and most of the things they do these days...i sold both my 86's over 3 yrs ago. but these are going on my mx73 for the time being.. i was just going to turn them back to stock. i don't feel like changing my bearings all the time!
    since they are only 160 USD i think i'm going to pick them up..have them polished and if i don't like them re-sell them. should be able to get at least what i put into them in return.. especially cleaned up.
    as far as all the bolts in the right pattern.. are there any markings to look for???
    I reckon my simmons would look hektik with the centres turned around
    my simmons rears would look identical (except unpolished)
  1. changing wheels on ke70
    By spoon in forum Tech and Conversions
    Last Post: 04-01-2006, 07:47 PM
