Results 16 to 30 of 57
Thread: 2jz-gte Experts.......
    Default Re: 2jz-gte Experts.......
    Correct. Japan 2JZ CT20A, US 2JZ CT12B
    Quote Originally Posted by cambelt1
    So do any of them say ct 12 b or ct 20 b on them. all the ones ive seen just say toyota.
    Mine have CT20A on the compressor housings, but most others I've seen just have Toyota. I'm not sure why the difference, but according to the Toyota EPC they all have the same part number.
    Equipped with Bowls Hat Backyard Mechanic Adam_Cressi's Avatar
    Norbie to the rescue cheers dude, i was wondering the same question
    +ve for you
    2JZ-GTE MX-83 Cressida
    Toymods Car Club Club Member # 185
    this is a bit of a "how long is a peice of string question"
    What sort of grunt are people getting out of 2JZ's with a bar of boost and bolt ons such as exhaust and bigger FMIC?
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    Nay sayer Domestic Engineer Mr Ed's Avatar
    May 2006
    About 230rwkw. 1bar is just above the boost cut point so youll need an FCD of some type to run this.
    Max Ive seen is 300rwkw on JDM stock turbos (yes I mean stock, not hiflowed or steel wheeled)
    I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
    241rwkw through and auto is what I have. And yes the turbos are definitely ceramic.
    May 2006
    Quote Originally Posted by 2JZR31
    Youre running more than 1bar though arent you??
    hmmm ok
    good food for thought, naturally I am enquiring in regards to my aristo..so its auto as well
    thanks for that people
    also how the hell do you get 300rwkw from stock turbos?
    wouildnt they just fall apart?
    Quote Originally Posted by Sir_2jza70
    I am on the street in cold weather and long ramp rates (high gears). I wish I had a boost readout on the dyno that day but I bet it would have been around 15 psi 16psi tops with the heat and short ramp rate.
    May 2006
    They lasted quite a while. The guy is now doing a big single swap and I dont think hes doing it cos his twins died. Yes it is crazy but he has dyno slips and trap times to back it up.
    His name is Thadius on supraforums.com.au
    phuck me thats insane....is he sure they were cearmic??
    This guy also claims he ran 135mph on a standard 2JZ with stock turbos with usual mild upgrades. 135mph is good for a high 9 second pass and equates to around 620hp in a car of that weight. I am more than skeptical...
    I have also seen 300rwkw. Southo on PF recorded one or two KW under the triple ton through an auto. (stock ecu usual basic mods, but with an accidental massive boost spike above 20psi) Even with the boost spike I am skeptical this reading was a true reflection that can be used as a comparison. Dyno readings are almost pointless for comparisons unless the same cars are compared on the same dyno on the same day.
    im not skeptical, i say hes full of shit.
    not time slip to back it up, there is no way in hell it ran 135mph trap speed on stock twins, not without about a 100 shot of gas.
    8.3 et PB 169 MPH PB
    747 to put it bluntly, yep
  1. 550cc US 2jz injectors into 1jz
    By Esselte in forum Tech and Conversions
    Last Post: 26-07-2007, 01:18 PM
  2. 1jz to 2jz
  3. 2JZ damaged, other options?
    By jzk25 in forum Tech and Conversions
    Last Post: 11-07-2006, 05:47 PM
  4. 1jz vs 2jz heads
