so when ignition is on there is 12v supply? or even with the igintion off?
the pump has constant power when the ignition is on anyways......you dont want it to be running when the engine is off.
also its a safety issue, if you crash and the pump stays running, it will pump fuel everywhere. very dangerous and chances of fire are very high
... I remove the fuel pump resistor and relay on most engine swaps I'm involved in, unless specifically asked to leave it in. None of the vehicles in question suffer any sort of problems with overfueling at lower rpm ranges, as evidence by many dyno runs with afr measurement.
