Results 16 to 18 of 18
Thread: Constant 12 volt fuel pump supply
    Default Re: Constant 12 volt fuel pump supply
    perhaps you could wire an LED from the fuel pumps power to ground... so that you can see whenever the pump has power...
    that way, if it is momentarily dieing as it switches over, you will see it...
    fuel pump momentarily losing power might do it.... but it should take a few seconds for the fuel pressure to decrease anyway...
    it sounds like poor tuning... but ya never know fuel pump voltage mod sounds cheaper and easier to try first
    You probably won't see the LED turning off the switching time would be in the order of tens of milli seconds.
    The pump should have enough mechanical inertia to run through the switchover anyway...
    Mos.
    Nay sayer Domestic Engineer Mr Ed's Avatar
    May 2006
    Quote Originally Posted by shinybluesteel
    yours didn't have a circuit opening relay?
    My GA70 circuit did but my 2JZ doesnt have an AFM to switch it open.
    I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
  1. HELP - how to wire up a fuel pump
    Last Post: 21-06-2007, 01:15 PM
  2. MS85 Fuel Pump.
    By Brad-KE35 in forum Tech and Conversions
    Last Post: 31-03-2006, 10:12 AM
  3. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 09:14 PM
  4. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
