Results 16 to 30 of 53
Thread: V8 Soarer Won't rev past 3800RPM
    Default Re: V8 Soarer Won't rev past 3800RPM
    where the hell is the map sensor on a 1uz
    first time ive heard of it
    and have never seen a mao sensor on a std 1uz
    Go to the Soarer Forum and find someone that is willing to swap ecu's for a trial. It sounds like its when it goes to open loop on the throttle. But it could also be any number of the above suggestions. The ecu swap is just an easy one to rule out, with a 10 min effort.
    Quote Originally Posted by ChuckLandwehr
    The 1UZ-FE in the Soarer's rum MAP sensor as well air air flow meter. Just check to make sure the MAP sensor is still connected. Top LH on intake plenum.
    Excuse me?
    Canada
    Add me to the list of those who has never seen a MAP sensor equipped #UZ.
    For any model year, from 1990 LS / 1992 SC400 to present.
    Jun 2006
    I unpluged the TPS and it still did the same thing.
    And i've never seen a map equiped 1uz either
    I does the same thing if i creap upto the rpm's or full throttle up. It feels like a electronic rev cut, like you would get at 7000plus rpm
    It has to be something electronic, as the way that its acting it can't be a spark plug, block fuel lines or anything like that, has to be either a fualty something or an unpluged something, i haven't found anything as yet to be unpluged
    Does it do it in neutral as well?
    Is it a 'bouncing' off the rev limiter (ie, cutting every 2nd injector pulse)
    Or is it just holding it at 3800 smoothly?
    Jun 2006
    Bouncing off and yes it does it in neutral
    The car just came up with an error code
    Picture attached anyone know what it means
    south australia
    its japanese. mine is to rusty to read it. a few toymodders can read japanese, you will have to wait for them to check it up
    That warning light is just saying you have a tail light blown
    http://www.hotkey.net.au/~cheets/war...ning_codes.htm
    I'd do as Trav suggested, pull a couple of plugs, see if they are covered in water/oil.
    Jun 2006
    Dammit, a tail light is blown. Geez japanese think of everything. I didn't think there error codes went down to such detail
    If it was a couple of plugs it would be showing up in the rev range everywhere not just at 3800rpm and not the way its acting up
    Junior Member Backyard Mechanic v8soarer's Avatar
    Jun 2006
    Put it in diagnostics mode by jumpering TE1 and E1 in the diagnostics connector in the engine bay then turn on the ignition. Any error codes will be displayed on the LCD in the dash.
    Some of the codes are listed here:
    http://soarercentral.com/sc-forum/me...tml?1101095275
    My TT 6 speed manual V8 Soarer (sold)
    Wakefield: 1:06.7
    Phillip Island: 1:51.9
    Sounds to me like ECU, either engine or fuel pump. Where abouts in Quensland are you?
    GT4 Freak, and Conversion King Squid's Avatar
    Quote Originally Posted by v8soarer
    That should get you pointed in the right direction... + rep
    Jun 2006
    sunshine coast
    Have you resolved your problem yet?
  1. Dash error codes on Jzz30 Soarer
    By RLR in forum Tech and Conversions
    Last Post: 25-03-2006, 04:38 AM
